A question re. 'single-particle' states
  • Thread starter "Don't panic!"
  • Tags
    States
In summary, the conversation discusses the concept of "single-particle states" in statistical mechanics. The term refers to the quantum states that each individual particle can occupy, regardless of whether the system's wave function can be expressed as a product of single-particle states or not. In cases where it can be, the energy eigenvalues of the microstates can be expressed as a sum of the energy eigenstates corresponding to each single-particle state. However, in systems with interacting particles, the concept of single-particle states is not applicable due to the quantum aspect of entanglement. It is advised to focus on the basics and avoid extending the concepts beyond the material in the course notes.
"Don't panic!"
601
Hi,
Seasons greetings to everyone :-)
I've been revising statistical mechanics and have stumbled across an area that I've always been a little 'hazy' on.
By the term 'single-particle' state, is it meant that this is a particular quantum state that one (or more) particle(s) can occupy, a term which holds true regardless of whether the wave-function describing the whole system is separable?
My understanding, quite possibly incorrect, is that single-particle states are the quantum states that each individual particle occupy (of course, it may be that more than one individual particle occupies the same quantum state), regardless of whether the wave-function describing the system can be expressed as a product of the wave-functions describing each single-particle state, or not. In cases where it can be, it is then possible to express the energy eigenvalues of the microstates of the system as a sum of the energy eigenstates corresponding to each single-particle state.
Please enlighten me if this is incorrect.
Many thanks.
A "single particle state" is, strictly, a state of a system with only one particle in it.
However, in many particle systems, it is possible for many particles to occupy a particular single-particle state ... i.e. Bose-Einstein statistics.
Note: iirc the term is not jargon, so watch the context.
I have found Sze Tan quite clear: http://home.comcast.net/~szemengtan/
Thanks for your speedy response.
So would it be correct to consider a multi-particle system in a given microstate as a collection of sub-systems, each containing a single-particle in a particular state, where it is possible that there is more than one 'copy' of the same sub-system?
(Or is this type of description only valid if one considers cases in which the particles are weakly interacting, such they can be treated as independent?)
No - because of the peculiar quantum aspect of entanglement.
Basically this is if you have two particles that can be in state |a> and |b> then they can be entangled in a way that doesn't allow them to be considered as two separate systems ie it is in a superposition of particle 1 in state |a> with particle 2 in state |b> and particle 1 in state |b> with particle 2 in state |a> ie c1*|a>|b> + c2*|b>|a>.
Just as an aside there is a view that this is the rock bottom essence of QM:
http://arxiv.org/pdf/0911.0695v1.pdf
Basically it would seem that the two most reasonable generalized probability models for modelling physical systems is ordinary probability theory and QM - but QM is the only one that allows entanglement.
Thanks
Bill
It is only correct for non-interacting particles. For a finite number of interacting particles, the single-particle states are just used to make basis vectors for the Hilbert space, and the state is then some superposition of basis vectors.
http://www.eng.fsu.edu/~dommelen/quantum/style_a/symways.html
http://www.itp.phys.ethz.ch/education/fs12/cqp/chapter04.pdf
Since you are reviewing the basics - you are best advised to avoid extending the concepts you are reviewing beyond the material actually in the course notes for that level. You are reviewing a very simple model that will be built on later on.
Baby steps.
Ok, I'll keep reading.
Thank you for your help guys, much appreciated!
FAQ: A question re. 'single-particle' states
What are single-particle states?
Single-particle states refer to the quantum states of a single particle in a system, such as an electron in an atom or a photon in a beam of light. These states are described by quantum numbers and can have unique energy levels and other properties.
How are single-particle states different from multi-particle states?
Single-particle states describe the properties of a single particle, while multi-particle states take into account the interactions and correlations between multiple particles. Single-particle states can be used as a simplification in certain systems, but they do not fully capture the complexity of multi-particle systems.
What is the significance of single-particle states in quantum mechanics?
In quantum mechanics, single-particle states play a crucial role in understanding the behavior and properties of individual particles. They are used to describe the behavior of particles in various systems, and their properties can be used to predict and analyze experimental results.
How are single-particle states related to the wave-particle duality of quantum mechanics?
The concept of single-particle states is closely related to the wave-particle duality of quantum mechanics. In this duality, particles can exhibit both wave-like and particle-like behavior, and single-particle states can be described by wavefunctions that represent the probability of a particle's location and behavior.
Can single-particle states be observed or measured?
Single-particle states themselves cannot be directly observed or measured, as they are abstract mathematical descriptions of a particle's quantum state. However, the properties and behaviors of particles described by these states can be observed and measured through various experiments and techniques.
