A question regarding electronic negative feedback
In summary: It doesn't always exactly predict and produce it - it settles to a point where the feedback error is minimised. The resistor in series with the input is part of the prediction. The output goes to a voltage where the feedback error is minimised. The circuit, as part of the feedback, uses the adjustment to produce the output. The difference between the input and output is amplified by the open loop gain. It is a 'guess' that works well.
Faiq
348
I have a confusion understanding one of the basic assumption used for operational amplifiers which is Vin = 0 or difference of inputs = 0.
Take for example an ideal amplifier with inputs V+ and V-
V+ = 1
V- = 0.5 * Vout
Supply Voltage = +-9
Vin = V+ - V-
At start V+ = 1 and V- = 0, providing us a Vin of 1V. Since gain is infinite, Vout = +9.
Now V+=1 and V- = 4.5, providing us a Vin of -3.5. Since gain is infinite, Vout = -9
Now V+=1 and V- = -4.5, providing us a Vin of 5.5. Since gain is infinite, Vout = +9
My question is in this example Vin doesn't approaches 0. So can you explain how does an operational amplifier will work in this situation to make Vin = 0?
Don't set it as a discrete time series. Set it as a single equation at one moment in time and solve. Also leave the gain as a variable and then once you have the solution in terms of the gain take the limit as it goes to infinity.
Why do you want Vin=0? This applies to an idealized (unrealistic) case only (open-loop gain Aol infinite).
If you really want to understand why - and at which voltage - the opamp settles, you must consider a real device with a finite Aol (large, but not infinite).
1.) You can start as in your example.
2.) On its way from -9V to +9V the voltage at the inv. input node tends to cross a positive value of V1=Vout/2 which fulfills the condition Vout=(1V-V1)*Aol.
This value of V1 will be slightly below the pos. input of 1V. When the difference Vd=(1V-V1) fulfills the condition Vd*Aol=Vout the system has reached its equilibrium and the system has settled.
It takes a little backward thinking to get past this all too common mental stumbling block .
It is the duty of the circuit designer
to surround the opamp
with a circuit that allows the opamp to drive its inputs equal, ie to zero* difference.
(* we say zero, in reality it's Vout/(Open Loop Gain).
Open loop gain is AVol on datasheet, 105 is a common value.
So , if output is to be less than Vs, difference at inputs must be less than Vs/AVol
For your case
<9/105 = <0.00009 which rounds to zero.
Simplest circuit is unity gain voltage follower
where input signal goes to + input pin
and - input pin is wired directly to output pin
wherever + input pin goes, - input pin will follow as far as power supply allows.
It can only operate within the constraints of power supply (and the common mode limit s of the selected amplifier, given in its datasheet.)
Don't feel alone, i had exact same problem in 1966.
Likes sophiecentaur
This is one of the best statements I have ever seen that sums up (no pun intended) opamp operation. (Again, no pun intended).
Likes dlgoff
The 'Virtual Earth' amplifier does this. The circuit feedback and biasing keeps the V- input at Zero Volts but it isn't actually connected to 'Earth'. The sum of currents in and out of the terminal is kept at zero.
@Faiq: Putting numerical values in at the start of any analysis is not useful.** You need to use Algebra. The basic equations that are used in OpAmp theory are not hard and they will tell you how the circuit actually performs. If you try putting a random selection numbers in, you end up with the output going to + or - supply voltage, which is no use. This Hyperphysics page has relevant equations.
** This is rather like trying to work out simple resistive networks without algebra. You can't tell what any particular component does until you include it in the whole picture. That will nearly always lead you into writing down an algebraic equation. (Except when you have done it so often that the answer is intuitive.)
Likes Dale
This simplifies many of the confusions yet raises a new question. How can a circuit predict the required voltage and produce it?
You are talking about what happens in the short period after switch on. Fact is that is complicated because of the different time delays in different electronics components. It is only necessary to write down the steady state situation (after things have settled down**). The circuit doesn't actually need to "predict" anything (and this is a popular misconception and the cause of a lot of confusion with beginners). Currents flow through components until a steady state is reached. This, conceptually, is similar to a mechanical system of masses connected together with springs and with a bit of friction involved. The arrangement reaches a state of equilibrium with each spring taking up a length appropriate to the forces on it. It doesn't need to 'know' anything at all about the rest of the set up.
** There are feedback circuits which will never actually settle down (unstable oscillators). They contain reactive elements (capacitors and inductors) and the volts and current around the circuit keep chasing each other and never actually catch up to reach equilibrium. There is a well known saying that "Amplifiers will oscillate and oscillators will amplify - just to be awkward". Stick with the ideal static circuits to start with.
Likes jim hardy and Averagesupernova
Didn`t you read (or didn`t you understand) my post#3 ? It explains why and when the system has reached an equilibrium state.
It doesn't have to predict anything.
All the circuit has to do is detect imbalance and drive toward balance.
Mother Nature loves a balance. So do operational amplifier circuit designers. I presume you're studying to become one.
I'd recommend you buy a breadboard , some LM324's, a resistor assortment , 9v battery and a voltmeter . Then you can build and troubleshoot circuits.
We learn faster by 'doing' than by 'reading about doing'.
Print yourself a copy of this document
https://www.ti.com/ww/en/bobpease/assets/AN-31.pdf
and study the clever circuits
if you get really interested , these guys "Wrote the Book" .
http://web.mit.edu/6.101/www/reference/op_amps_everyone.pdf
it's 400+ pages , so
Print and keep a hardcopy in a binder or buy a copy it'll be a lifelong resource.
Likes Averagesupernova
Related to A question regarding electronic negative feedback
1. What is electronic negative feedback?
Electronic negative feedback is a process in which the output of a system is fed back to the input in order to regulate or stabilize the system's behavior. In electronic circuits, negative feedback is achieved by using a feedback loop that compares the output signal to a reference signal and adjusts the input signal accordingly.
2. What is the purpose of using electronic negative feedback?
The primary purpose of using electronic negative feedback is to improve the performance and stability of a system. It allows for better control and regulation of the output signal, leading to more accurate and consistent results. It can also reduce distortion and noise in electronic circuits.
3. How does electronic negative feedback work?
In electronic circuits, negative feedback is achieved by using a feedback loop that consists of a comparator, an amplifier, and a feedback path. The output signal is compared to a reference signal and the result is amplified and fed back to the input. This causes the input signal to be adjusted in a way that reduces the difference between the output and reference signals, resulting in a more stable and accurate output.
4. What are the benefits of using electronic negative feedback?
Using electronic negative feedback can lead to improved stability, accuracy, and linearity in electronic circuits. It can also help to reduce distortion and noise, and increase the overall reliability of the system. Additionally, negative feedback can allow for easier control and adjustment of the output signal.
5. Are there any drawbacks to using electronic negative feedback?
While electronic negative feedback can have many benefits, there are also some potential drawbacks to consider. For example, too much negative feedback can lead to instability and oscillations in the system. It can also increase the complexity of the circuit and may introduce additional sources of error. Therefore, it is important to carefully design and implement negative feedback in electronic circuits to avoid these potential issues.
  • Electrical Engineering
  • Other Physics Topics
18K
  • Classical Physics
