B A question regarding Heliocentric Latitude
  • B
  • Thread starter Thread starter Mikael17
The discussion centers on the heliocentric latitude of planets, specifically the highest and lowest positions of Earth relative to the Sun's equator, occurring in March and September, respectively. It questions whether these points are fixed or if they exhibit movement similar to Mercury's perihelion precession. The latitudinal movement is influenced by the planets' tilted orbital planes, while the rotation axis is independent of these planes, leading to asynchronous timing of effects. The periods of these movements are complex, described by polynomials with numerous coefficients. Apsidal precession, which affects the long axis of a planet's orbit, results from various phenomena, with some aspects only fully understood in the 20th century.
Mikael17
TL;DR Summary
Are lower / higher points of Heliocentric Latitude always taking place same time ervery year.?
By following the link below you can see (an animation) showing how the planets that orbiting the Sun each year have their lowest / highest position (relative to the Sun's equator).
The lowest point of the Earth is seen every year in the month of September, (and the highest position of the Earth occurs in March).
My question is whether these "points" over time are immovably fixed, or whether they "move" / "rotate" - in the same way that perihelion also moves (for example Mercury's perihelion precession).
If these "points" move over time, what is the reason and how much do they move?
Astronomy news on Phys.org
The plane of each orbit is close to the ecliptic. The latitudinal movement modelled in the graphics is a function of the planet's movement on those tilted orbital planes.
The axis of planet rotation is independent of the planet's orbital plane about the Sun. For that reason, the timing of the two effects will be asynchronous.
The periods are not so much determined, as they are described by polynomials having hundreds of complex coefficients.
The year is different for each planet. Apsidal precession is the rotation of the long axis of the orbit in the planet's orbital plane.
https://en.wikipedia.org/wiki/Apsidal_precession
Cause: "The apsidal precessions of the Earth and other planets are the result of a plethora of phenomena, of which a part remained difficult to account for until the 20th century when the last unidentified part of Mercury's precession was precisely explained. "
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
