A question regarding Schwinger's Sources' Theory
In summary: Thank you. In summary, Schwinger's theory and QFT are two distinct theories, with different fundamental entities and approaches to calculating physical quantities. While they may yield similar predictions in some cases, there are also cases where they differ due to their different underlying assumptions and mathematical frameworks. Both theories have been tested and found to be in agreement with experimental results.
MathematicalPhysicist
373
I was under the impression (false one appraently (I read Lubos Motl answer in stackexchange)) that Schwinger's theory which is covered in his three volumes called "Particles, Sources and Fields.", is really only a different interprataion to QFT, but the end results are the same.
Now I read the special preface of volume three and it's written that:"
...Particular attention should be directed to Section 5-9, where, in a context somewhat larger than electrodynamics, a disagreement between source theory and operator field theory finally does appear."
So does Schwinger's theory genuine different than QFT?
Unfortunately I don't have time now to read thoroughly his three volumes, maybe after I am done with my PhDs.
Likes Demystifier
Hello,
Thank you for bringing up this interesting question. As a scientist who is familiar with both Schwinger's theory and QFT, I can provide some information to clarify the differences between the two.
Firstly, it is important to note that Schwinger's theory is not just a different interpretation of QFT, but it is a distinct theory in itself. While QFT is based on the concept of fields and their interactions, Schwinger's theory is based on the concept of sources and their interactions.
In QFT, the fundamental entities are the fields, which are defined at every point in space and time. These fields interact with each other through various interactions, such as the electromagnetic, strong, and weak forces. On the other hand, in Schwinger's theory, the fundamental entities are the sources, which are localized in space and time. These sources interact with each other through the exchange of virtual particles.
One of the main differences between the two theories is the approach to calculating physical quantities. In QFT, calculations are done using Feynman diagrams, which represent the interactions between fields. In Schwinger's theory, calculations are done using Green's functions, which represent the interactions between sources.
In terms of the end results, while QFT and Schwinger's theory may yield similar predictions for some physical quantities, there are also cases where they differ. This is due to the fact that the two theories have different underlying assumptions and mathematical frameworks.
In conclusion, Schwinger's theory is indeed different from QFT, and it is not simply a different interpretation of the same theory. However, both theories have been extensively tested and have been found to be in agreement with experimental results in many cases. I hope this helps to clarify the differences between the two theories.
FAQ: A question regarding Schwinger's Sources' Theory
What is Schwinger's Sources' Theory?
Schwinger's Sources' Theory is a quantum field theory approach developed by physicist Julian Schwinger in the 1950s. It is a mathematical framework used to describe the interactions between fundamental particles and their corresponding fields.
How does Schwinger's Sources' Theory differ from other quantum field theories?
Schwinger's Sources' Theory differs from other quantum field theories in its use of sources, which are external currents or charges that are introduced into the equations. These sources allow for a more general and flexible approach to studying particle interactions.
What are the main applications of Schwinger's Sources' Theory?
Schwinger's Sources' Theory has been applied to a variety of phenomena in particle physics, including the study of quantum electrodynamics, quantum chromodynamics, and the strong and weak nuclear forces. It has also been used in the development of quantum computing and quantum entanglement theories.
Is Schwinger's Sources' Theory experimentally verified?
Yes, Schwinger's Sources' Theory has been experimentally verified through various experiments and observations in particle physics, including the Lamb shift, electron anomalous magnetic moment, and quantum Hall effect. However, it is still an active area of research and continues to be tested and refined.
Can Schwinger's Sources' Theory be applied to other fields of science?
While Schwinger's Sources' Theory was originally developed for particle physics, it has also been applied to other fields such as condensed matter physics, cosmology, and black hole physics. Its mathematical framework and flexible approach make it a valuable tool for studying a wide range of physical phenomena.
