A question related to de Broglie wavelength and the Uncertainty Principle
In summary, the uncertainty principle states that the product of the standard deviations of two conjugate observables must be greater than or equal to the reduced Planck's constant divided by two. This is a fundamental principle in quantum mechanics and arises mathematically from the Fourier transform of these observables. The uncertainty principle has been experimentally confirmed and plays a crucial role in understanding the behavior of particles at the quantum level.
Rishabh Narula
61
"Now, if an electron has a definite momentum p,
(i.e.del p = 0), by the de Broglie relation, it
has a definite wavelength.A wave of definite
(single) wavelength extends all over space.
By Born’s probability interpretation this
means that the electron is not localised in
any finite region of space. That is, its
position uncertainty is infinite
(del x --> infinity ), which is consistent with
the uncertainty principle."
-high school physics book from India,NCERT
Physics 12th part 2.
Why does a wave of definite wavelength extend
all over the space?
Or why does it continue/goes on forever
just because it has one value for wavelength?
And why should then the opposite be true that
a wave packet consisting of different wavelengths
doesn't continue/goes on forever?
i.e I'm asking what does the opposite case
that is these lines mean-
"The wave packet description of
an electron. The wave packet corresponds to a
spread of wavelength around some central
wavelength (and hence by de Broglie relation,
a spread in momentum)."
Please explain simply if you can,my
understanding of this stuff is a beginner
level as of now.
Try:
https://physics.mq.edu.au/~jcresser/Phys304/Handouts/QuantumPhysicsNotes.pdf
The short answer is that a wave-packet is only localised when you superimpose an infinite number of waves with wavelengths over a continuous spectrum. In some ways this is an amazing mathematical trick.
It doesn't become localised just because you add a few waves together of different wavelengths.
Likes QuantumQuest, vanhees71 and Rishabh Narula
PeroK said:
Try:
thanks,but i still don't really get it.Is there an internet video or pictures explaining this?could you link those too.will go through the pdf and reply further too thanks.
This is serious undergraduate level physics. If you cannot follow an undergraduate level text, then there is no simpler explanation. You just have to accept that a mathematical process called a Fourier transform does the trick and move on.
Note that the diagrams on page 16 of the jpf couldn't be clearer on this point.
One should be highly suspicious if they have a physical quantity that is infinite. Limits to infinity are generally okay, but not actual undefined quantities like infinity.
"That is, its position uncertainty is infinite (del x --> infinity ), which is consistent with the uncertainty principle." -high school physics book from India,NCERT Physics 12th part 2.
This statement from your book is not true. It can be seen to be not true at least two ways.
1) The Fourier transform of a delta function is an infinite wave. The integral of the probability of a single infinite wave is infinity so it is not normalizable, and thus it isn't a legitimate wave function in quantum mechanics.
2) Heisenberg's uncertainty principal deals with the standard deviations of position and momentum of a wave function: ##\Delta x \Delta p \ge \frac{\hbar}{2}##. From OP's textbook, we are given ##\Delta x = \infty ## and ##\Delta p = 0##. Depending on who you ask, if you multiply these two together you will either get zero or something undefined. Either way, it won't satisfy the inequality.
Likes bhobba and vanhees71
See if this helps...
"Heisenberg's uncertainty principle for conjugate pairs of observables follows directly from the fact that those observables are essentially the Fourier transforms of each other."
Mathpages
This is not true in general but for position and momentum only. Of course it's a very intuitive example. If you have the Fourier transformation of a narrow-peaked function in momentum space to the function in position space,
$$f(x)=\int_{\mathbb{R}} \mathrm{d} p \frac{1}{\sqrt{2 \pi}} \exp(\mathrm{i} p x) \tilde{f}(p),$$
you'll see that ##f## is a broad distribution. If on the other hand ##\tilde{f}(p)## is a broad distribution, ##f(x)## will be a narrow-peaked function.
Quantitatively the uncertainty relation for an arbitrary pair of observable ##A## and ##B##, represented by self-adjoint operators ##\hat{A}## and ##\hat{B}## reads
$$\Delta A \Delta B \geq \frac{1}{2} |\langle [\hat{A},\hat{B}] \rangle|.$$
Here ##\Delta A## and ##\Delta B## are the standard deviations of the quantities calculated with the state ##\hat{\rho}## the system under consideration is prepared in:
$$\langle \hat{X} \rangle:=\mathrm{Tr}(\hat{\rho} \hat{X}),$$
with the standard deviation defined as
$$\Delta A^2 = \langle \hat{A}^2 \rangle - \langle \hat{A} \rangle^2.$$
Then ##[\hat{A},\hat{B}]## is the commutator of the two operators.
For position and momentum you have
$$[\hat{x},\hat{p}]=\frac{1}{2} \mathrm{i} \hbar$$
and thus the uncertainty relation
$$\Delta x \Delta p \geq \frac{1}{2} \hbar.$$
Likes QuantumQuest
Related to A question related to de Broglie wavelength and the Uncertainty Principle
1. What is the de Broglie wavelength?
The de Broglie wavelength is a concept in quantum mechanics that describes the wave-like behavior of matter. It is named after French physicist Louis de Broglie and is calculated using the momentum of a particle divided by its mass.
2. How is the de Broglie wavelength related to the Uncertainty Principle?
The de Broglie wavelength is related to the Uncertainty Principle, which states that it is impossible to know both the position and momentum of a particle with absolute certainty. The de Broglie wavelength is a measure of the uncertainty in the momentum of a particle.
3. What is the significance of the de Broglie wavelength in quantum mechanics?
The de Broglie wavelength is significant because it helps explain the wave-particle duality of matter. It shows that particles, such as electrons, can exhibit both wave-like and particle-like behavior, and their wavelength can be calculated using their momentum.
4. How does the de Broglie wavelength change with the mass of a particle?
The de Broglie wavelength is inversely proportional to the mass of a particle. This means that as the mass of a particle increases, its de Broglie wavelength decreases. This relationship is important in understanding the behavior of different types of particles in quantum mechanics.
5. Can the de Broglie wavelength be observed in real-life experiments?
Yes, the de Broglie wavelength has been observed in many experiments, such as the famous double-slit experiment. This experiment showed that even large particles, such as electrons, can exhibit wave-like behavior and have a de Broglie wavelength. This further supports the wave-particle duality of matter in quantum mechanics.
  • Quantum Interpretations and Foundations
