A Radiation Shock Too Powerful to Examine (EMP)
In summary: well, to anything, really. They seem to be more susceptible to things that we normally don't think about.That's definitely part of the story.
Quotidian
98
Hi all - I'm not a physics grad, my knowledge is limited to whatever I can glean from popular science publications. Anyway, I'm crafting a hard sci-fi story - 'hard' because it's written to seem kind of plausible, or at least not outrageously surreal - no shape-shifting or anti-gravity or wormholes.
A central feature of the story is a radiation shock which affects Northern Europe. The idea is based on EMP research - the fact that a high-altitude nuke can set off an electromagnetic pulse capable of destroying microprocessors. This is what seems to happen, except that there is no discernable nuclear explosion - it seems instead to have an interstellar origin. It immediately disables the computers in millions of cars and a very large number of satellites. It's not strictly apocalyptic, because it affects only a bounded area, and doesn't directly affect humans, but it's pretty catastrophic, also causing a number of SCADAs to fail in power utilities and the like.
At this point, my intuition about what's feasible and what's not reaches its limit. The way I've described it, the event is so powerful that it basically wrecks any of the instruments that would normally record such events. So after the event, there's precious little by way of forensics as to where it originated or how powerful it was, as it basically blew the dials on anything that might normally be expected to record it.
Remember, this is a fiction story, but I want to retain at least an edge of plausibility, so I thought I would run it by this forum to see if you all fall about laughing at it.
For obvious reasons, we won't be discussing too many technical details about EMP generation or damage here at PF. The Wikipedia articles are a good place to start for you, IMO. You can start with this one and then look at the Nuclear EMP Weapon article for more directed (no pun intended) references:
https://en.wikipedia.org/wiki/Electromagnetic_pulse
This article is about the phenomenon in general. For nuclear EMP weapons, see Nuclear electromagnetic pulse. For Earth magnetosphere pulsations, see Magnetic pulsations.
Likes Quotidian
Recently a gamma ray burst affected the ionosphere enough to disturb radio transmissions. It came from 2.4 billion light years away. It came from a star collapsing into a black hole. If that happened a thousand light years away it seems to me that it would do the job and more. Having it affect only a limited region seems kind of unrealistic -- I think it would wipe out everything -- but this is fiction.
Likes Quotidian and berkeman
If it happened with the Moon between the source and Earth, would the Moon protect the shadowed part of the Earth, or would diffraction around the Moon keep that from happening?
Interesting idea. It turns out to be interstellar, and the source seems to be related to a supernovae event, but, as I say, it turns out to be very difficult to analyse - which is a part of the story.
That's also part of the story, and one of the reasons that it defies analysis.
The story mentions the Carrington Event in 1854, which is really interesting in its own right, for those who've never heard of it. Definitly worth googling.
Likes hutchphd and BvU
Also detonation Starfish (prime) which produced unexpectedly large localized EMP effects on other side of the equator from a Mega-ton sized warhead at 100 miles altitude
thanks, great tip. Hadn't heard of that one. 'Starfish Prime caused an electromagnetic pulse (EMP) that was far larger than expected, so much larger that it drove much of the instrumentation off scale, causing great difficulty in getting accurate measurements.' Bingo!
Likes hutchphd
I can't think of a natural phenomenon that is focused enough on a limited area. So how about unnatural phenomena. You could have a large solar energy collector orbiting a Lagrange point like the Webb telescope or in a plain ordinary Earth-like solar orbit far from Earth. It beams the energy to Earth. It gets hit by a solar flare that messes up the best laid plans of mice and men. There is a plan to fold up the collector in such a case but it doesn't work (darn). The beam moves randomly about Earth for a while.
By the way, it seems to me that living things are more vulnerable to ionizing radiation than are computers, so that radiation would kill everything in the vicinity with possibly a delay of a week or two.
Your post reminded me of this
https://www.scientificamerican.com/...which seems,season in the Northern Hemisphere.
Likes Quotidian
That is not correct. As witnessed by the aforementioned starfish series of nuclear tests which killed no person (directly at least) but wreaked havoc on instruments. This is why I mentioned them.
Some ionizing radiation can be focussed by magnetic fields yet have a high cross-section in matter. This makes for quite variable effects.
Likes pinball1970
I would check out my post on Chernobyl frogs and the Ecosystem they inhabit.
I don't know anything about instruments but some species appear to be able to endure relatively high and prolonged levels of radiation.
That becomes the main question (but I don't want to give too much away).
Yes but I suppose the instruments were much closer to the detonation than was any unsheltered person.
"To give you a comparison of effects, it takes a radiation dose of about 5 Sv to cause death to most people. Diodes and computer chips will show very little functional detriment up to about 50 to 100 Sv. Also, some electronics can be "hardened" (made to be not affected as much by larger gamma radiation doses) by providing shielding or by selecting radiation-resistant materials." Though it is true that he specified that it exceed the design limits of the detection device, not actually destroy it, so maybe I'm off base with this.
You could have longer wavelength non-ionizing radiation like microwaves. Living things are less affected by that.
https://hps.org/publicinformation/ate/q11162.html
It is my understanding that the detonation was at 250 miles altitude and the instruments in question were in 900 miles away in Honolulu. The instrumentation effects were caused by induced currents and potentials from the EMP as mediated by the Earth magnetic field, not the direct effects of ionizing radiation. Luckilly, in this case at least, we are not that conductive nor are we large. Please read the documentation.
FAQ: A Radiation Shock Too Powerful to Examine (EMP)
What exactly is a radiation shock?
A radiation shock, also known as an electromagnetic pulse (EMP), is a burst of electromagnetic energy that can be caused by a variety of sources such as nuclear explosions, lightning, or solar flares. It can disrupt or damage electronic devices and communication systems.
How powerful can an EMP be?
An EMP can be extremely powerful, with the potential to release energy in the form of gamma rays, X-rays, and radio waves. The strength of an EMP is measured in kilovolts per meter (kV/m) and can range from a few thousand volts per meter to millions of volts per meter.
What are the potential effects of a powerful EMP?
A powerful EMP can have a wide range of effects, depending on the strength and proximity to the source. It can cause damage to electronic equipment, disrupt communication and transportation systems, and even cause power outages. In extreme cases, it can also pose a threat to human health and safety.
Can we protect against EMPs?
There are measures that can be taken to protect against EMPs, such as shielding electronic devices and systems with metal or other materials that can block electromagnetic waves. However, complete protection against a powerful EMP is challenging and may require specialized equipment and infrastructure.
Are there any natural occurrences of EMPs?
Yes, EMPs can occur naturally from events such as solar flares or lightning strikes. These natural EMPs are typically less powerful than those caused by human-made sources, but they can still cause disruptions to electronic systems and infrastructure.
