Emspak
- 243
- 1
Find <r> and <r2> for an electron in the ground state of hydrogen. Express in terms of Bohr radius.
We know the relevant wave functions are:
[itex]R_{10} = \frac{c_0}{a}e^{r/a}Y^0_0[/itex]
and [itex]Y^0_0 = \frac{1}{\sqrt{4\pi}}[/itex]
As I understand it the way to get <r> is to do the following integral
## \langle r \rangle = \int^{2\pi}_0 \int^{\pi}_0 \int^{\infty}_0 r |R_{10}|^2 r^2|Y^0_0|^2 dr d\theta d\phi ##
when I pug everything in, knowing that ## c_0 = \frac{2}{\sqrt{a}} ## I get
## \langle r \rangle = \int^{2\pi}_0 \int^{\pi}_0 \int^{\infty}_0 r^3 \frac{2}{a^3}e^{-2r/a} \frac{1}{4\pi} dr d\theta d\phi ##
and i can ignore (for the moment) the outer two integrals because the quantity <r> doesn't depend on either phi or theta.
So that leaves me integrating this:
## \langle r \rangle = \int^{\infty}_0 r^3 \frac{2}{a^3}e^{-2r/a} \frac{1}{4\pi} dr = \frac{1}{2 \pi a^3} \int^{\infty}_0 r^3 \frac{2}{a^3}e^{-2r/a}dr ##
Integrating by parts with ## u = r^3 ##, ## du = 3r^2 dr ##, ## dv = e^{2r/a} ## and ## v = \frac{-ae^{2r/a}}{2} ## that gets me to
## r^3 \frac{-ae^{-2r/a}}{2} - \int^{\infty}_0 \frac{-ae^{2r/a}}{2} 3r^2 dr = -r^3 \frac{ae^{-2r/a}}{2} + \frac{3}{2} \int^{\infty}_0 ae^{-2r/a} r^2 dr = r^3 \frac{ae^{-2r/a}}{2} + \frac{3a}{2} \int^{\infty}_0 e^{-2r/a} r^2 dr ##
the first term goes to zero. integrating by parts again, with ## u = r^2 ## and ## du = 2rdr ## the same thing happens:
## \frac{1}{2 \pi a^3} \frac{3}{2} \left[ -ar^2 \frac{e^{-2r/a}}{2} + \int^{\infty}_0 \frac{ae^{-2r/a}}{2} 2r dr \right] ##
that first term goes to zero again. OK so next up is another integration by parts. ## u = 2r ## and ## du = 2dr ## so
##\frac{1}{2 \pi a^3} \frac{3}{4} \left[ -2ar \frac{e^{-2r/a}}{2} + \int^{\infty}_0 \ ae^{-2r/a} dr \right] ##
and we do it all once more, to get
## \langle r \rangle = \frac{3}{8 \pi a^2} \frac{-ae^{-2r/a}}{2} |^{\infty}_0 = \frac{3}{8 \pi a^2} \left[0 + \frac{a}{2} \right] = \frac{3}{16\pi a} ##
Problem is this isn't what the various solutions I have seen to the problem gets, which is 3a/2.
So, my question is where the mistake I am making is. I posted it here because I suspect the problem is some elementary operation (rather than a deep physics problem) I am not doing right, some algebraic thing I screwed up but I went through this twice so far and can't seem to pin it down. That factor of pi has to go away somehow, for example. (In the two outer integrals maybe?)
thanks.
