A robot that is programmed to react to external stimuli
  • Thread starter Tabaristiio
  • Tags
    Robot
In summary, a robot that is programmed to react to external stimuli must have a program that sends information to the screen at a very fast speed in order to avoid any delays or errors. Additionally, the robot must also have a sensor that detects external stimuli quickly in order to avoid any physical delays.
Tabaristiio
61
A robot that is programmed to react to external stimuli, what factors determine the speed at which it detects / recognizes the stimuli?
Suppose this robot is programmed to respond to various different external stimuli, such as clicking a button when a color changes, clicking a button when something appears in a blank screen, evading a punch / kick etc.
This question focuses purely on the stimuli recognition / detection speed and not the actual physical action / reaction speed.
Say I wanted to program this robot to detect / recognize various different stimuli at 0.1 milliseconds, what has to be done to achieve this?
When I say various different external stimuli, I mean it being multi - situational. So this robot should detect / recognize various different external stimuli in 0.1 millisecond.
For example, detecting a punch / kick from 5 inches away at 0.1 millisecond. Detecting a color change in a computer screen in 0.1 millisecond. Detecting a pistol making sound (like in 100 sprints) in 0.1 millisecond. Detecting something appearing in a computer screen in 0.1 millisecond etc.
I've learned that using photo diodes can be useful for detecting color changes very fast. However, can it be equally helpful for detecting other external stimuli such as detecting a random piston sound, punches, kicks, etc. or is it purely for detecting color changes?
Is there something that can be used to improve detection speed for all external stimuli or is it specific to different ones?
Please note that my question is purely focusing on visual and auditory external stimuli and detection speed.
Another important note is that my question is purely driven out of curiosity. It's not a professional job or anything alike. I'm just trying to learn this out of curiosity.
Thanks in advanced!
I just wanted to add one more thing. Even if the specifications I put forward isn't possible, such as a reaction time of 0.1 second, then please state what has to be done to the robot for it to get the fastest reaction time that is possible. Whether it's 0.10 milliseconds, or 0.50 etc.
You're limited by how fast the information is sent to the screen, and is received from the camera.
A LCD monitor doesn't flicker, but the screen is still only refreshed 60 times/second, so that takes >16ms.
A camera won't send one image faster, unless you have an extremely expensive one. Then you'll need software to recognize what's happening in the image.
Ignoring the limitations of the signal source, for an image the time required is based upon the speed of light (generally a sufficient speed in other than astronomical distances), the internal signal transfer time and the processing time of the robot detection system; but, for audible inputs the speed of sound in the atmosphere related to the distance between the source signal; and the robot detector could be factor as well.
In the case of multiple sources of inputsdevoted sensors and multiple parallel processors could be required as well since most data acquisition systems utilize multiplexing which, similar to the refreshing time mentioned above, is a sequential sensor data input reading process.
Related to A robot that is programmed to react to external stimuli
1. How does a robot react to external stimuli?
A robot that is programmed to react to external stimuli has sensors that detect different types of stimuli, such as light, sound, and touch. These sensors send signals to the robot's central processing unit (CPU), which then analyzes the data and determines the appropriate response.
2. Can a robot be programmed to react differently to different stimuli?
Yes, a robot can be programmed to react differently to different types of stimuli. The programming of the robot's CPU determines how it will respond to different stimuli. For example, a robot may be programmed to move towards a sound but avoid bright light.
3. How quickly can a robot react to external stimuli?
The speed at which a robot can react to external stimuli depends on its programming, as well as the complexity of the stimuli and the response required. Some robots are designed to react and respond quickly, while others may have a slower response time.
4. What are the benefits of using a robot that can react to external stimuli?
A robot that can react to external stimuli can be used in a variety of applications, such as industrial automation, healthcare, and consumer electronics. It can improve efficiency and accuracy in tasks that require quick reactions and can also be used in environments that may be dangerous for humans.
5. Are there any limitations to a robot's ability to react to external stimuli?
While robots can be programmed to react to a wide range of external stimuli, their responses are limited by their programming and the capabilities of their sensors. They may also have difficulty responding to unexpected or complex stimuli that they have not been programmed to recognize.
  • STEM Career Guidance
  • STEM Academic Advising
  • Art, Music, History, and Linguistics
