A rolling ball, find distance traveled
To determine the distance traveled by a rolling ball, focus on the second half of the time interval to find acceleration, which simplifies calculating the distance for the first 5 seconds. The position as a function of time can be derived from the equation of motion, where position varies quadratically with time. A suggested method involves using a spreadsheet to adjust acceleration until the distance in the second 5 seconds equals 200 meters, allowing for the calculation of the first 5 seconds' distance. Understanding the relationship between velocity and time through graphical representation can also clarify the distance covered, as the area under the velocity-time curve represents the distance. This approach emphasizes the importance of grasping fundamental principles for efficient problem-solving.
rebbe90
A ball starts from rest and rolls down a hill with uniform acceleration, traveling 200m during the second 5s of it's motion. How far did it roll during it's first 5s of motion.
V = s/t
I figured the best way to do this is to focus on the second half of time. We can use the information there to find acceleration and that should make it fairly simple to find distance traveled in the first 5 seconds. Average speed in 5s-10s I found to be 40m/s.
My problem is that to find the acceleration I think I have to find the position as a function of time and derive it. Stuck on how to make the function.
The standard expressions of uniform acceleration tell you that the position varies quadratically with time, ##x = \frac{1}{2} at^2 \propto t^2##. If you double the time, then by what factor does the position increase?
Likes Steve4Physics, bob012345 and PeroK
What about using a spreadsheet and setting a variable equal to a value of acceleration. Then compute the distance in the first ##5s## and in the second ##5s##. Tune the variable until the distance in the second ##5s## is ##200m##. That would give you the answer for the first ##5s##.
Then, try to figure out algebraically what the tuning process is doing.
This hint is a great example of how understanding the principles involved will quickly cut through a mass of formulas and get to the right answer fast, especially useful on a test.
I add a geometric suggestion to the others. The distance covered over a time interval is the area under the velocity vs. time curve. Look at the v vs. t graph below. The distance covered in the first 5 s is represented by the area in red. The distance covered in the next 5 s is represented by the area in green. If the green area is 200 m, how big is the red area?
Likes bob012345 and PeroK
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
