A rope of 5m is fastened to two hooks 4m apart on a horizontal ceiling
  • Thread starter Thread starter verb tense
    Horizontal Rope
A 5m rope is fastened between two hooks 4m apart, supporting a 10kg mass, creating segments of 3m and 2m. Participants discuss the formation of a triangle due to the rope's curvature and the application of the sine and cosine rules to find angles and tensions. Initial calculations yield tensions of 73.5N and 49.1N, but corrections emphasize the need to differentiate between the triangle of distances and the triangle of forces. After refining the angles, tensions are recalculated to 88.5N and 69.5N, with a suggestion to explore an alternative method using vertical and horizontal components. The discussion highlights the importance of accurate diagram representation in solving the problem.
verb tense
A rope of 5m is fastened to two hooks 4m apart on a horizontal ceiling. To the rope is attached 10kg mass so that the segment of the rope are 3m and 2m.Compute the tension in the string
Sine rule
I get stuck at the part that says '10kg mass so that the segment of the rope are 3m and 2m'. Please i just need the right diagram i know what to do.
Let us imagine we are hanging the mass to the rope.Right?
Yes.
So if one fastened a 5m rope to two hooks at a horizontal distance 4m apart, the rope will hang in a curve. But when the mass is hung at the specified point, what will happen to the rope? (assume the rope does not extend)
We are trying to do it together!
A triangle is formed.
So one knows the all the sides of this triangle. But I do not think that he sine rule can be used because there are to many unknowns for this rule to be used. Hence one can use the cosine rule to find the angles.
Ok let me try it out.
I got the angles to be 104,47 and 29 am i right and what next?
Likes Nerve
Correct but it is better to work with 104.5, 46.6 and 29.0 deg.
Now you can either use the sine rule or use components of the tensions.
Here is a diagram.
i got the tension to be 73.5N and 49.1N
if you show the working I can tell you where there is something not correct.
Here it is.
Using the sine rule is ok but it is being used in the wrong triangle. Note that the tiangle of the set up of the apparatus is not necessarily a traingle of forces. In fact the triangle you are using is a traingle of distances not forces.
Try to draw a triagle of the forces showing the directions of the weight, tension1 and tension2. Then put the angles required for this traingle of forces. If you need further help just ask.
Need help don't know what to do.:confused:
Look at the diagram of the forces and fit in its angles using information form the diagram of the apparatus.
Ok is this it?
How can the angle at the bottom of your diagram be 104deg if it must be LESS than 90deg.
Try again to get the angles of the FORCES diagram. The information required for this can be obained from the diagram of the strings attached to the mass.
For example tension T1 will make angle 43.4deg with the vertical.
I think i got it
That is correct!
Remember. There is a diagram for the distances and a diagram for the forces.
Okay , so this is what i got for tension 88.5N and 69.5N
Correct.
There is another way how to do it.
Ok, Thanks.
Please can you show me the other way to do it?
One starts from the diagram in the attachment. Then the vertical and horizontal components of the tensions are drawn.Try to do that.
... and then one can compare the two methods.
10K
9K
