A satellite, the sun and the satellites heat protector
In summary, the equilibrium temperature of a spacecraft's baffle, protected from the Sun's radiation by a planar baffle aligned perpendicular to the Sun's direction, can be calculated using the flux of the Sun and the flux of the Sun's radiation on the baffle. The final result is given by $T_b=\Big(\frac{\alpha_d^2}{8}\Big)^{\frac{1}{4}}T_s$, where $T_s$ is the heat of the Sun, 5800K, and $\alpha_d$ is the angular diameter of the Sun as seen from the spacecraft. The small angle approximation can be applied, but is not necessary to obtain the result.
Olly_price
A spacecraft is protected from the Sun’s radiation by a planar baffle whose size is much greater than that of the spacecraft itself. The baffle is aligned perpendicular to the direction of the Sun. Show that the equilibrium temperature of the baffle is $$T_b=\Big(\frac{\alpha_d^2}{8}\Big)^{\frac{1}{4}}T_s$$ where T_s is the heat of the sun and is 5800K, $\alpha_d$ is the angular diameter of the Sun as seen from the spacecraft .
Flux of the sun = L / $2\pi d^2$ where $d$ is the distance of the Sun from the baffle and L is the luminosity of the Sun.
Any classical equations involving thermal equilibriums etc.
I was thinking of using the flux of the Sun stated above, and then the flux of the Sun's radiation on the baffle, considering the Sun's rays projected onto the baffle. Some form of ratios may help, but I didn't get anywhere.
I also tried using some geometries involving the angular diameter but could not successfully isolate $\alpha$. Perhaps we need to take a small angle approximation?
You can use that approach. It is probably useful to introduce some variable for its area. It will cancel out later but it makes the formulas easier to follow.
The final result looks like it uses that approximation, yes, but it should not be necessary to get a result.
Related to A satellite, the sun and the satellites heat protector
What is a satellite?
A satellite is an object that orbits around a larger object in space, such as a planet or a star. Satellites can be natural, like the moon, or man-made, like the ones used for communication and navigation.
How does a satellite stay in orbit?
A satellite stays in orbit due to the balance between its forward motion and the pull of gravity from the larger object it is orbiting. This is known as centripetal force.
What is the sun?
The sun is a star at the center of our solar system. It is a giant, glowing ball of gas that provides heat and light to the planets in our solar system. It is also the largest and most massive object in our solar system.
Why do satellites need a heat protector?
Satellites need a heat protector because they are exposed to intense heat from the sun's radiation. Without a heat protector, the satellite's delicate instruments and electronics could be damaged or even destroyed.
How does a satellite's heat protector work?
A satellite's heat protector, also known as a thermal shield, is made of special materials that can reflect or absorb heat. It helps to regulate the temperature inside the satellite and protects it from the sun's intense heat and radiation.
  • Thermodynamics
20K
