A simple change in gravitational energy, but I want to be certain.
In summary: Thanks for clearing that up for me.In summary, the author is looking for a quantitative representation of death risk in a manned spaceflight to Mars. They use the equation for gravitational potential energy to try and find a really big number that represents certain death. The changes in gravitational energy involved in a manned spaceflight to Mars are immense, but are resolved by reducing the acceleration of the rocket.
US-RB
Welcome to the Australian Physics course! I have to analyse the effects of changes on gravitational energy and radiation from the Sun on a manned spaceflight to Mars. I doubt my abilities to solve simple problems, however, so I now turn to the vast collective of the Internet to aid me. I simply want to know if my calculation for the potential energy of my hypothetical rocket is correct. I seek a quantitative representation of the danger associated with takeoff and landing in this situation, so I have used the equation for gravitational potential energy to try and find a really big number that represents certain death.
I'm hoping that I only need to use:
[itex]E=mgh[/itex]
Why do I say 'Welcome to the Australian physics course'? It seems that other countries have far less text in their physics than we do. As a result, I offer the TL;DR version, where I take the mass of the Saturn V rocket and assume low-Earth orbit at 300km, using normal Earth acceleration:
[itex] E=mgh[/itex]
[itex] E= (3039000)(9.8)(300000)=8.93 \times 10^{12} J[/itex]
Alternatively, you may read the full article in which this calculation features.
The changes in gravitational energy involved in a manned spaceflight to Mars are immense. Consider the Saturn V rocket, with a mass of just over three million kilograms. It is known that gravitational potential energy is given by E=mgh, so if this rocket is fired into a low-earth orbit of 300km, it will have a gravitational potential energy of 8.93 terajoules (8.93x10^12 J), only counting the height of the rocket from the surface of the earth. The total mass of the rocket after it had completed the takeoff process, however, was only 131,300kg. This new mass gives only 386 gigajoules (3.86x10^11 J) of gravitational potential energy. Subjecting a human being to this amount of energy would kill the person, so the rocket must be designed to protect any passengers onboard. Luckily, this impulse is being distributed over a long period of time, as the sheer size of the rocket poses a large inertia. To accelerate this mass immediately would be inefficient and painful for anyone close enough to see the rocket launch. This is using the definition of impulse as I=F/dt. The huge force of the rocket is spread over a large time, reducing the impulse, which reduces the potential of damage to the crew. So the changes in gravitational energy are immense, but the issue is resolved by reducing the acceleration of the rocket so that the related impulse is reduced. This reduction of the acceleration is performed both on takeoff from Earth and entry to Mars. There is also an issue of the crew’s bones weakening, due to the lack of significant gravity in space. Centrifuges are used to combat this, creating a force equal to gravity on the crew member’s body.
GPE=mgh is approximately correct for low Earth orbit. But there is about 5% error in your answer due to this approximation. So your calculation is roughly right. For a more accurate answer, you should use Newton's law of gravitation.
About the main article, It think you've got force and impulse mixed up. Impulse is the change in momentum and so impulse divided by time equals the average force, not the other way around.
Bruce, I believe you are correct here. I just looked through my book and saw I=FΔt. So if I revised my wording to be along the lines of 'Force is reduced as time increases, as force is proportional to the product of impulse and the inverse of time', would I now be correct?
yep, pretty much. although technically, it is impulse divided by a period of time which gives the average force. So when you say 'force is reduced as time increases', this may cause confusion, because it sounds like you're talking about instantaneous force.
Excellent, thanks. I'll modify my work and feel far more secure now.
FAQ: A simple change in gravitational energy, but I want to be certain.
1. How does a simple change in gravitational energy occur?
A simple change in gravitational energy can occur when an object either gains or loses height, or when the distance between two objects changes. This can happen due to external forces, such as a push or pull, or due to changes in the mass of one or both objects.
2. What factors affect the amount of gravitational energy in a system?
The amount of gravitational energy in a system is affected by the mass and height of the objects involved. The greater the mass and height, the greater the gravitational energy. Additionally, the distance between the objects also plays a role, as the gravitational force decreases with distance.
3. Can a simple change in gravitational energy have a significant impact?
Yes, even a small change in gravitational energy can have a significant impact. For example, a slight change in the height of a water dam can greatly affect the amount of gravitational energy stored and impact the power it generates.
4. How is gravitational energy related to potential energy?
Gravitational energy is a type of potential energy that is stored in an object due to its position in a gravitational field. It is the energy that is required to move an object from its current position to a reference position, usually at a great distance away.
5. Can a simple change in gravitational energy be reversed?
Yes, a simple change in gravitational energy can be reversed. For example, if an object falls from a certain height, it loses gravitational energy. However, if it is lifted back to its original height, the gravitational energy is restored. This is due to the principle of conservation of energy, which states that energy cannot be created or destroyed, only transferred or transformed.
