MHB A simple (?) combinatorial problem
  • Thread starter Thread starter lfdahl
The combinatorial problem involves distributing 20 identical items among 10 different persons, with each person allowed to receive between zero and five items. The Stars and Bars method is not applicable due to the item limit per person, making the problem more complex. A suggested solution is to programmatically enumerate all possibilities, which is feasible given the upper boundary of 6^10. A Python function was provided to calculate the number of distributions, yielding a result of 2,930,455. The original poster expressed gratitude for the assistance and plans to adapt the code for use in SciLab.
lfdahl
MHB
As simple as it seems, I still can´t figure out how to solve the following combinatorial problem:
In how many ways can 20 identical items be distributed among 10 (different) persons, when each person may have from zero to five items?
Thankyou in advance for any help, that can lead me on the right path ...
Hey lfdahl,
It would be simple if we could apply the Stars and bars method.
But since we have a maximum of 5 items per person, I believe it's not so simple.
Simplest that I can come up with, is to programmatically enumerate all possibilities.
That should be doable since we have an upper boundary of $6^{10}$, which is still feasible.
In python:
Code:
""" Number of ways to divide o identical objects over p persons
where each person receives 0 to m objects.
def recurse(o, p, m):
	if p == 1:
		return 1 if o <= m else 0
	n = 0
	for i in range(0, min(m, o) + 1):
		n += recurse(o - i, p - 1, m);
	return n;
print recurse(20, 10, 5);
Result is [M]2930455[/M].
I like Serena said:
Hey lfdahl,
In python:
Code:
	if p == 1:
	n = 0
	return n;
Hey, I like Serena
Thanks a lot for your thorough answer to my problem!
Although I´m not familiar with python, I will see, if I can write your codes in SciLab.
I really appreciate your help!
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
