A simple limit that causes a lot of headache
  • Thread starter Marin
  • Tags
    Limit
In summary, you could consider the derivative and some careful estimates show that it is always negative (and exponentially grows in the -infinity direction).
Marin
193
Hi everyone!
consider the following limit:
[tex]\lim_{x\rightarrow\infty}\frac{ln(1-\frac{1}{x})}{e^{-x}}[/tex]
Since we get [0/0] (by injectivity of both exp and log functions), it smelled to me like de l'Hospital's rule until I began calculating the derivatives. Then I realized it's somehow useless...
Besides the correct value of the limit, I am also very interested in the point, why the rule is not applicable here :)
I appreciate every idea or hint you give me :)
thanks a lot in advance,
marin
The rule applies, I think, but it doesn't help you as it keeps giving 0/0.
You could consider the derivative and some careful estimates show that it is always negative (and exponentially grows in the -infinity direction).
Or you could use a formal argument after rewriting something like
[tex]\lim_{x \to \infty} \ln(1 - 1/x) e^{-x} = \lim_{y \to 0} \ln(1 - y) / e^y = e^{\ln(\ln(1 - y))} e^{-y}[/tex]
ok, i'll stick to the formal argument. Could you please elaborate on what exactly you do there. It's obviously not the substitution y=1/x, is it, since you should've changed the whole argument of the exp funct. and not just replace its sign? Well, how does it work then?
Whoops, my mistake. You are right, I cannot do that.
It is intuitively clear that e^{-x} will go to 0 faster than ln(1 - 1/x) will. Perhaps substituting y = 1/x and making a Taylor expansion around y = 0?
Also note that the derivative argument, if written down correctly, is no less formal.
As [itex]x \to \infty[/itex], 1/x is small, so the logarithm can be approximated by
[tex]\ln (1 - \frac1x) \approx - \frac1x[/tex]
Then it should be clear what is happening in the limit.
ETA:
Actually, l'Hopital's should have worked just fine. I get
[tex]-\lim_{x \to \infty} \frac{e^x}{x-x^2}[/tex]
Remember that [tex] ln(1 - 1/x) = - \int_{1 - 1/x}^1 \frac{1}{u} du [/tex]
So your expression is [tex] -e^x \int_{1 - 1/x}^1 \frac{1}{u} du [/tex]. By the MVT of integral calculus [tex] \int_{1 - 1/x}^1 \frac{1}{u} du = \frac{1}{x} \frac{1}{c} [/tex] where c is some value between 1 - 1/x and 1.
Your expression in your limit is now [tex] \frac{-e^x}{xc} [/tex]. Since c is some value between 1 - 1/x and 1, we see that as x tends to infinity 1/c tends to 1 and it is easy to see that the rest of the expression then goes to negative infinity.
Double Post
Ben Niehoff, you're right, l'Hospital works fine here after doing a bit of algebra :), btw, I think you've got a minus sign more/less in your answer, since the answer is -infty :)
JG89, I find your solution using the MVT very elegant, thanks for posting it :)
CompuChip, Taylor expansion also works very well :)So, thanks once again for the help!
FAQ: A simple limit that causes a lot of headache
What is a limit in science?
A limit in science refers to the maximum or minimum value that a physical or mathematical quantity can approach, but not exceed, under certain conditions. It is often used to describe the boundaries or constraints of a system or process.
How does a simple limit cause a lot of headache?
A simple limit can cause a lot of headache because it can lead to unexpected or undesirable outcomes in experiments or calculations. It can also be challenging to accurately determine or predict a limit, especially when dealing with complex systems.
What are some examples of simple limits in science?
Some examples of simple limits in science include the maximum amount of weight that a bridge can support, the minimum temperature at which water freezes, and the maximum speed that an object can travel in a vacuum.
How do scientists deal with limits in their research?
Scientists deal with limits in their research by conducting experiments and collecting data to better understand the boundaries and constraints of a system. They also use mathematical models and simulations to predict and analyze limits before conducting experiments.
Can limits be exceeded in science?
Yes, limits can be exceeded in science under certain circumstances. For example, a limit may be exceeded if there is a malfunction in equipment or if the conditions of the experiment change. However, exceeding a limit can lead to inaccurate results or even potential harm, so scientists strive to stay within the established limits in their research.
