A solution of Euler's equation
In summary, the conversation discusses the calculation of pressure in a fluid with a given velocity vector and constant density, as well as a body force applied. Using Euler's equation and solving for P, the book's solution is obtained by solving three partial differential equations with t as a fixed parameter. The del operator plays a role in this process.
coverband
171
The velocity vector for a flow is u = (xt, yt, -2zt). Given that the density is constant and that the body force is F = (0,0,-g) find the pressure, P(x,t) in the fluid which satisfies [tex]P = P_0(t) [/tex] at x = 0
Euler's equation: [tex] \frac{Du}{Dt}=-\frac{1}{\rho}\nabla P + F [/tex]
[tex] \nabla P = \rho(-x-xt^2, -y - yt^2, 2z - 4zt^2 - g) [/tex]
How do you get P from this. Back of the book gives
[tex] P = - \frac {1}{2} \rho (x^2+y^2)(1+t^2) + \rho z^2(1-2t^2)-\rho gz + P_0(t) [/tex]
How did they get that?
What do you understand by the del operator? You simply have to solve a set of three partial differential equations to reconstruct P.
More specifically, you have
[tex]\frac{\partial P}{\partial x}= \rho(x- xt^2)= \rho(1- t^2)x[/tex]
[tex]\frac{\partial P}{\partial y}= \rho(y- yt^2)= \rho(1- t^2)y[/tex]
and
[tex]\frac{\partial P}{\partial z}= \rho(z- zt^2)= \rho(1- t^2)z[/tex]
Which can be treated as three ordinary differential equations with 't' as a fixed parameter.
The arbitrary function of t comes into play as you're doing a partial integration, so when you take the gradient again, all functions of t get knocked out as you're doing partial differentiation.
Thanks I was getting delta mixed up with nabla!
Related to A solution of Euler's equation
1. What is Euler's equation?
Euler's equation is a mathematical formula that describes the relationship between the three fundamental mathematical constants: e (the base of the natural logarithm), pi (the ratio of a circle's circumference to its diameter), and i (the imaginary unit).
2. What is a solution of Euler's equation?
A solution of Euler's equation is a value or set of values for the three constants (e, pi, and i) that makes the equation true. It is also known as a "triple" or "triple solution".
3. Why is Euler's equation important?
Euler's equation is important because it links together three of the most important and seemingly unrelated mathematical constants. It has applications in fields such as physics, engineering, and finance, and is considered one of the most beautiful and elegant equations in mathematics.
4. How is Euler's equation used in real-world problems?
Euler's equation can be used to model and solve a wide range of real-world problems, such as predicting the growth of compound interest, analyzing the behavior of electrical circuits, and understanding the motion of waves.
5. Are there any other versions of Euler's equation?
Yes, there are several other versions of Euler's equation that involve different combinations of mathematical constants. Some examples include Euler's identity (e^(i*pi) + 1 = 0) and the Basel problem (sum of 1/n^2 = pi^2/6).
