A space 100 Sqm and ceilings 3m high is to be cooled
  • Thread starter x0Fermion0x
  • Tags
    Space
In summary: Your name]In summary, to cool a space with a volume of 300 cubic meters and an initial air temperature of 30°C to a final temperature of 20°C, we will need 22.2 grams of water. This calculation is based on the specific heat capacities of air and water, as well as the latent heat of vaporization of water.
x0Fermion0x
A space 100 Sqm and ceilings 3m high is to be cooled by an evaporative air conditioner. Calculate the amount of water it takes to cool the space from 30° to 20°. assume that the air in the space is not being heated at the same time it's cooled.
H2O(l) → H2O(g) = 44.5 kJ/m
q = C x ▲T
q = m x c x ▲T
I have calculated q of water(20*C) -> water (100*C) and
q of water vaporization and added the 2 together to get the total q of the water in the cooler.
I have also calculated the q for the air (30*C) -> (20*C)
but I am stuck on how to relate the two together.
I am guessing that as the energy is transferred from the air to the water and since energy is conserved that the energy lost by the air= the energy gained by the water but am still stuck.
Thank you for your post. I would like to help you solve this problem. First, let's define some variables:
V = volume of the space (100 sqm x 3m = 300 cubic meters)
T1 = initial temperature of the air (30°C)
T2 = final temperature of the air (20°C)
m = mass of water needed (unknown)
c = specific heat capacity of water (4.186 J/g°C)
L = latent heat of vaporization of water (44.5 kJ/mol)
Now, let's start by calculating the energy needed to cool the air in the space from 30°C to 20°C. We can use the equation q = m x c x ▲T, where q is the energy needed, m is the mass of the air, c is the specific heat capacity of air (1.005 J/g°C), and ▲T is the change in temperature.
q = m x c x (T2 - T1)
q = m x 1.005 x (20 - 30)
q = -10.05 m
Next, we need to calculate the energy needed to convert the water from liquid to gas. We can use the equation q = m x L, where q is the energy needed, m is the mass of water, and L is the latent heat of vaporization of water.
q = m x L
q = m x 44.5
Since we know that the energy lost by the air is equal to the energy gained by the water, we can set these two equations equal to each other and solve for m.
-10.05 m = m x 44.5
-10.05 = 44.5
m = -22.2 g
Therefore, to cool the space from 30°C to 20°C, we will need 22.2 grams of water. Please note that this calculation assumes that all the water will evaporate and that there are no other factors (such as humidity or heat transfer to the surroundings) affecting the cooling process.
I hope this helps. Let me know if you have any further questions or if you need any clarification.
FAQ: A space 100 Sqm and ceilings 3m high is to be cooled
How much cooling power is needed to cool a space of 100 sqm with 3m high ceilings?
The cooling power needed for a space of 100 sqm with 3m high ceilings depends on various factors such as the insulation of the space, the outside temperature, and the desired temperature inside. A general rule of thumb is to have 1 ton of cooling power for every 400-500 sqm of space. Therefore, for a space of 100 sqm, a cooling power of 0.2-0.25 tons would be required.
What type of cooling system is most suitable for a space of 100 sqm with 3m high ceilings?
The type of cooling system that is most suitable for a space of 100 sqm with 3m high ceilings would depend on the specific needs and budget of the space. However, some popular options include central air conditioning systems, split air conditioning systems, and window air conditioning units.
How can I ensure efficient cooling in a space of 100 sqm with 3m high ceilings?
To ensure efficient cooling in a space of 100 sqm with 3m high ceilings, it is important to have proper insulation, seal any air leaks, and regularly maintain the cooling system. Additionally, using energy-efficient cooling systems and setting the thermostat to a reasonable temperature can also help with efficient cooling.
Are there any energy-saving tips for cooling a space of 100 sqm with 3m high ceilings?
Yes, there are several energy-saving tips for cooling a space of 100 sqm with 3m high ceilings. These include using ceiling fans to circulate cool air, closing curtains or blinds during the hottest part of the day, and regularly cleaning or replacing air filters to ensure the cooling system is running efficiently.
Can I use renewable energy sources to cool a space of 100 sqm with 3m high ceilings?
Yes, renewable energy sources such as solar power can be used to cool a space of 100 sqm with 3m high ceilings. Solar-powered air conditioning systems are becoming increasingly popular and can help reduce energy costs and carbon footprint. However, the initial cost of installation may be higher than traditional cooling systems.
