A spring and two blocks with kinetic energy
In summary, when two masses collide, the kinetic energy is converted to spring energy and the distance that the spring is compressed is 0.173 m.
hs764
1. I have two blocks, one that is 1.6 kg moving left at 3.00 m/s and the other is 2.1 kg moving right at -1.74 m/s, and they are compressing a block with a spring constant of k=600 N/m. I'm supposed to be finding the distance that the spring is compressed at that instant, and I know that 1/2mv^2=1/2kx^2 but every other problem I've encountered only had one block and kinetic energy from only one direction, so I just want to make sure that I'm doing the right thing by combining the kinetic energy of the two blocks and then using that to solve for x. The answer I came up with is below but I'm not 100% sure that it's correct. 2. 1/2mv^2=1/2kx^23. 1/2(1.6)(3.00)^2 + 1/2(2.1)(-1.74)^2 = 1/2(600)x^2 x = 0.19 m
Hello hs, and welcome to PF :smile:
There is something missing from your problem statement, or something else is wrong. Is this the literal staement ? If not, could you post the complete, exact problem statement ?
Reason I ask is that from the given information (two masses with two velocities) the distance the spring is compressed at that moment can't be determined.
Ah, okay. Well it's a two part problem, but I may have gotten the first part wrong as well.
It says, "A block of mass m1 = 1.60 kg moving to the right with a speed of 4.00 m/s on a frictionless horizontal track collides with a spring attached to a second block of mass m2 = 2.10 kg moving to the left with a speed of 2.50 m/s, as in Figure 2. The spring has a spring constant of 600 N/m. At the instant when m1 is moving to the right with a speed of 3.00 m/s, determine (a) the velocity of m2 and (b) the distance x that the spring is compressed."
So for part a) I had worked out that the velocity of m2 was -1.74 m/s. Does that make sense?
Yes it does make sense. There is something going on before the velocity of m1 has dropped to 3 m/s: the spring has been compressed.
You get the -1.74 m/s from a momentum balance and it seems fine to me.
In post #1 you convert the remaining kinetic energy to spring energy. So that would result in an answer that gives the further compression of the spring (unitil no kinetic energy is lefet over.
I have the impression part (b) of the exercise is asking for something else. Don't you ?
Okay, so it's the kinetic energy that's already been lost that determines the value of x, so that changes x to 0.173 m...?
What's the calculation that gives you 0.173 m ?
It's the difference in kinetic energy, right? So [1/2(1.6)(4.0)^2 + 1/2(2.1)(-2.5)^2] - [1/2(1.6)(3.0)^2 + 1/2(2.1)(-1.74)^2] = 1/2kx^2, which gave me x = 0.173 m.
Excellent. (And yes, ahem, it was me who had an error in the calculation, so I was puzzled o:) )
Awesome, thanks for your help!
FAQ: A spring and two blocks with kinetic energy
How is kinetic energy related to a spring and two blocks?
Kinetic energy is the energy an object possesses due to its motion. In the case of a spring and two blocks, the kinetic energy is generated by the movement of the blocks as they compress and decompress the spring.
What factors affect the amount of kinetic energy in a system with a spring and two blocks?
The amount of kinetic energy in a system with a spring and two blocks is affected by the mass of the blocks, the speed at which they move, and the stiffness of the spring. Increasing any of these factors will result in an increase in kinetic energy.
Can kinetic energy be converted into potential energy in a system with a spring and two blocks?
Yes, kinetic energy can be converted into potential energy in a system with a spring and two blocks. When the blocks compress the spring, they store potential energy in the form of elastic potential energy. This energy can then be released back into kinetic energy when the spring decompresses and the blocks start to move.
How can the amount of kinetic energy in a system with a spring and two blocks be calculated?
The amount of kinetic energy in a system with a spring and two blocks can be calculated using the formula KE = 1/2mv^2, where m is the mass of the blocks and v is the velocity at which they are moving.
What is the difference between kinetic energy and potential energy in a system with a spring and two blocks?
Kinetic energy is the energy of motion, while potential energy is the energy stored in an object due to its position or configuration. In a system with a spring and two blocks, kinetic energy is generated by the movement of the blocks, while potential energy is stored in the compressed spring.
