skrat
- 748
- 8
A stick with mass ##m=0.1kg## and length ##a=0.5m## has on each end welded a spring with constant ##k=2000N/m## and length ##l=0.2m##. We stretch both of the springs and mount them on the sides of vertical walls which are ##d=1m## apart. Find both translational and rotational eigen frequency for small oscillations in horizontal plane.
Deflection of the stick due to it's mass is negligible.
And here we go again. Another problem I can't solve by myself.
I started writing dynamic equations for each direction separately. Since everything happens in the ##xy## plane I started with ##x## direction, where the origin is of course in the center of mass of the rod when in equilibrium position.
So ##m\ddot x=-F_1cos\vartheta -F_2cos\varphi ##
##m\ddot x= -ks_1cos\vartheta -ks_2cos\varphi ##
Where ##s=s_0+\delta s## is the stretch and ##s_0=d/2-a/2-l## initial deformation.
##s_1=s_0+(\sqrt{(l+x)^2+y^2}-s_0)=\sqrt{(l+x)^2+y^2}##
##s_2=s_0+(s_0-\sqrt{(l-x)^2+y^2})=2s_0-\sqrt{(l-x)^2+y^2}##
If I insert that into dynamic equation and also write cos in terms of x :
##cos\vartheta =\frac{d/2-a/2+x}{\sqrt{(l+x)^2+y^2}}## and ##cos\varphi =\frac{d/2-a/2-x}{\sqrt{(l-x)^2+y^2}}##
Now If I am not completely mistaken, this brings my dynamic equation to:
##m\ddot x= -2kx-\frac{ks_0}{l}(d/2-a/2)-\frac{ks_0x}{l}(d/2-a/2)##
The same idea goes for ##y## direction where I get
##m\ddot y =-\frac{2ks_0}{l}y##
All this must be terribly wrong. :D
