A strict proof of "why the Earth is a ball"
In summary, "A strict proof of 'why the Earth is a ball'" presents a detailed argument based on scientific principles and empirical observations that demonstrate the spherical nature of the Earth. It explores various lines of evidence, including gravity's role in shaping celestial bodies, the curvature of the horizon, the way ships disappear hull-first over the horizon, and the consistent round shape of Earth observed from space. The proof combines mathematical reasoning and experimental data to solidify the understanding of the Earth's geometry, countering misconceptions and supporting the consensus of a spherical Earth in the scientific community.
graphking
60
TL;DR Summary
Do you laugh when see the title?
I imitate the proof of "why bubbles are ballshpe"(due to the surface tension energy)
to generate a proof and make an essay.
"bubbles are ball" is called isoperimetric problem in serious mathematic. In this topic, many essay were written. Here's my serious essay about "why earth ball", which has been rejected by arxiv and my mentors...... I would want to know if physicists are interest?
I really think that is something worth to proof, but in fact my work is basic imitation of the isoperimetric problem (why bubbles are ball)
I would show your paper to your profs to get their feedback on your math.
The common consensus is that through measurement and experiment the Earth is roughly an oblate spheroid with a gravitational acceleration of about ##9.8 m/s^2##.
Its also likely that someone has gone through these same calculations before using Classical Mechanics and Calculus to model an oblate spheroid and considering the Earth’s rotational speed and pull of gravity from the Sun, Moon, and planets.
This modeling is valuable info for space agencies such as NASA and the Indian, Eurpean, Russian and Chinese Space Agencies for orbital mechanics.
Sadly, we cant review your work until its been published in a peer reviewed journal. I had to remove the link for that reason.
Likes graphking and berkeman
This to me sounds more like something I would hand out as an assignment in first year rather than something new that merits publishing.
Likes graphking
Doe your theory explain why smaller accretion objects are not spheres and does it define what "smaller" means?:check::flashlight:
that is a new view to me, I only pretty sure it must be sphere when the object is convex, adding small part maybe not convex?
The earth is not a ball. A ball is a toy. The word you are looking for is 'sphere'.
However, the earth is not a sphere either. It is, as has been mentioned, approximately an oblate sphereoid. Since it is not a sphere, any "rigorous proof" that it is a sphere is wrong.
If you have a proof that the earth is kindof-sortof spherical, how can such a mushy statement be rigorous?
In any event, you have not done what you set out to do, so it is unsurprising that it's been rejected by everyone who has seen it.
Most asteroids are not spheres. They are potatos. Phobos and Deimos are not spheres. Yet Luna is ~a sphere. Size matters.
I have seen some of them, but I can't fully strctly understand the calculate using legendre polynomials.
And as for the begining of all calculation base on small disturbing from sphere, I haven't found the proof of sphere in google, not so sure whether some journal has it
And here I thought there was some stuff below the infinisetimaly thin boundary consisting of a set of points at radius R from the centre. Why, I thought it might even be a closed ball (to the first approximation).
Is this thread an attempt to debunk all possible Flat Earth hypotheses ?
I am not certain OP understands the gravity of the situation … 😏
  • Haha
Likes pinball1970, phinds and berkeman
The Earth is provably not a sphere (as has already been pointed out, it is an oblate spheroid to good approximation).
Really?
And also, the asteroid belt would probably have been a planet (another oblate spheroid) in an orbit between Mars and Jupiter if it hadn't been for the disturbance of nearby Jupiter's enormous mass. Instead of forming a planet, they never got together and formed billions of rocks.
Likes graphking
Down with gravity! Up with levity!
Likes bob012345
what is the situation here? if it's not rotating, the gravity formula is modified?
  • Wow
Likes phinds
What? No.
Small bodies do not have strong enough gravity to overcome the structural strength of the rock they're made of. Large bodies (about the size if Ceres) simply collapse under their own weight into a nearly spherical configuration, with only small departures from sphericity such as mountain ranges and oceans. If such large objects spin they gain an equatorial bulge from the centrifugal force, as well.
Likes graphking
Also the temperature of the eqarly solar system would have been a lot higher so many of the early clumps of matter would have been hot enough to melt together into spheroids. Spinning could have limited their final size before cooling. But it's all very complicated and largish objects can melt due to tidal friction forces from nearby large objects. Io (a jovian moon) has active vulcanism due to this tidal effect.
There is a vast range of situations for astronomical objects that produce a whole range of different final results.
Likes Ibix
In your draft paper, you refer to the planet "earth".
Yet "Earth" is a proper noun, so it should be capitalised.
Soil or "earth", is the material in which plants grow.
Why earth is ball shape? That is an old question. To find out why earth is ball,
there’s two perspective:
Your failure to capitalise the proper noun "Earth", may explain why the paper was quickly rejected.
  • Care
Likes graphking
Poster has been reminded to avoid personal speculation at PF
Thank you all for more information from physics! I understand the real situation better.
What I can provide is an interesting fact that gravity maybe fail to exist in a 2-dimension world, because it cannot be the form of r^-2, and due to bertrand theorem, if you want a force can make 2 point rotate around each other periodically (when their distance over all time are bounded, that is just the situation of elliptic moving, not
Hyperbolic/parabola), the force must be r^-2 or r^1(spring force f=kx).
This is a gross and faulty representation of what Bertrand’s theorem actually says and its implications.
I know my expression is bad, I should google it, but what do you say about bertrand thm?
El thread-o es cerrado por un momento... :wink:
Likes jbriggs444 and SammyS
Since this thread is heading into personal speculation territory, it will remain closed. Thanks to everybody who tried to help the OP.
Likes jedishrfu and bob012345
FAQ: A strict proof of "why the Earth is a ball"
What evidence supports the idea that the Earth is a sphere?
The evidence supporting the idea that the Earth is a sphere includes observations of the horizon, which appears curved when viewed from high altitudes, the way ships disappear hull-first over the horizon, and the phenomenon of lunar eclipses where the Earth casts a round shadow on the moon. Additionally, satellite imagery and photos taken from space consistently show a round Earth.
How do we explain the round Earth using physics and mathematics?
Physics and mathematics explain the round Earth through the principles of gravity and the shape of celestial bodies. Gravity pulls matter into a shape that minimizes potential energy, which is a sphere. Mathematical models and equations, such as those used in geodesy, describe the Earth as an oblate spheroid, slightly flattened at the poles and bulging at the equator due to its rotation.
What role do satellite images play in proving the Earth's shape?
Satellite images play a crucial role in proving the Earth's shape by providing direct visual evidence of its roundness. Satellites orbiting the Earth capture images from space, showing a consistently round planet. These images are corroborated by data from multiple space agencies and independent sources, making them a reliable proof of the Earth’s spherical shape.
How do circumnavigation and global travel demonstrate the Earth's roundness?
Circumnavigation and global travel demonstrate the Earth's roundness by allowing travelers to start at one point and return to the same point by continuously moving in one direction. This would not be possible on a flat surface. Additionally, flight paths and shipping routes are planned based on a spherical Earth, and they work consistently with this model.
How do gravity and the behavior of objects in free fall support the spherical Earth theory?
Gravity supports the spherical Earth theory by pulling objects towards the center of mass, which results in a round shape. On a spherical Earth, gravity acts uniformly towards the center, causing objects in free fall to follow a curved path. This uniform gravitational pull is consistent with the observations of how objects fall and how the Earth’s surface curves away from a point of view.
