marellasunny
- 255
- 3
I am going to quote an article below and there is a part I would like clarification.I do not understand why chaotic differential systems do not have an analytical solutions. In the simplest form,an equation such as this one [sin(x) + x - 0.5 = 0] does not have an analytical solution i.e it can be only solved numerically.
1.What would be its equivalent for a differential system not having a analytical solution?
2.When the differential equation/system gives a different response for different initial conditions,how does it imply "not having a analytical solution"? I'm a novice.
Not all mechanical problems can be solved analytically as many physicist thought before. They thought that if there were no analytical solution then it was only a matter of intelligence, it would need a more clever mathematical approach to solve these problems.
In fact there are only some special problems that can be solved analytically. This doesn’t mean that Newton was wrong, he predicted chaotic motion.
Henri Poincaré was the first to see this. In a contest, by King Oscar II of Sweden and Norway, a few problems was to be solved, one of them was to prove that the solar system was stable (i.e. analytical solution exist). Poincaré found that there could not be an analytical solution, even the simpler problem of a three-body system. He found that a small difference in the initial conditions could blow up to a totally different answer.
