A thermal expansion coefficient of spacetime?
In summary: I see no reason to treat 'space' as possessing any ponderable properties [to borrow from Einstein]. It does appear, however, it can be treated as a field. Does that constitute a 'property'? That is unclear to me.I can understand how 'space' itself doesn't have any ponderable properties, but spacetime, I think even Einstein came to think of 'it' as a thing.If you can't describe how one would go about measuring it, it's not science.
ryan albery
67
Are there any theories or thoughts that view spacetime as 'having' a coefficient of thermal expansion... analogous to the CTE of water? An inflection with density in regards to temperature?
Space news on Phys.org
Well, since nobody knows what the cosmological constant actually is physically, such as maybe
dark energy, or not, who knows? Energy density, maybe; heat, not so much as far I can see.
If heat is transfrerred via conduction, convection and radiation, you'd need a mechanism that associates those kind of changes with varying cosmological expansion rates. But cosmological expansion doesn't seem well described temperature. Not only is the universe currently the coolest it has ever been, around 2.7 degrees C these days, expansion is currently accelerating as the universe continues to cool. And it expanded superluminally when it was really, really hot and cooling. So what expands superluminally when hot and cold and continues as it approaches absolute zero?
Density and pressure seem not 'in general' linearly/proportional to temperature, like an ideal gas.
No. How would you measure such a thing?
Same way as you'd measure the expansion/contraction of the universe, only assuming spacetime is an actual thing.
Maybe our ideas of space and time, or spacetime are so far myopic. Carlo Rovelli describes some discordances:
In SR, if you move along at a constant velocity, your time ticks off at a steady pace. Not so in GR...Proper time along a path [called a worldline] is an observable but it is not 'ticks at a steady pace'...
The proper time, tau, along spacetime trajectories cannot be used as an independent variable either, as tau is a complicated non-local function of the gravitational field itself. Therefore, properly speaking, GR does not admit a description as a system evolving in terms of an observable time variable. ...
This weakening of the notion of time in classical GR is rarely emphasized: After all, in classical
GR we may disregard the full dynamical structure of the theory and consider only individual solutions of its equations of motion. A single solution of the GR equations of motion determines “a spacetime”, where a notion of proper time is associated to each timelike worldline...
But in the quantum context a single solution of the dynamical equation is like a single “trajectory” of a quantum particle: in quantum theory there are no physical individual trajectories: there are only transition probabilities between observable eigenvalues. Therefore in quantum gravity it is likely to be impossible to describe the world in terms of a spacetime, in the same sense in which the motion of a quantum electron cannot be described in terms of a single trajectory.
Is there any definition for a temperature of the 'vacuum' of spacetime?
I guess for some "parts' it would be the Hawking Temperature.
What's the Planck Temperature really mean?
Ryan, I'm afraid that none of what you are writing makes any sense at all. I was trying to nudge you in a more scientific direction by asking how this is measured. But the idea of an expansion of a space of fixed volume does not make sense - it either has fixed volume or it does not. The idea of a temperature of an empty volume of space does not make sense either.
Yeah, data are by the things you measure. But to call anything other than data to be 'non-scientific'; not science, I disagree.
So empty spacetime can have a field (like the Higgs), contains dark energy, and transmits EM radiation and gravity, but the idea of temperature is undefined? I'm just trying to wrap my brain around that:)
The average temperature of the universe is definable. To define such changes per the era your calculating the average temperature. These calculations use variations of the ideal gas laws. Those laws involve the volume, density, number of particle species (ie photons,neutrinos etc), the interactions of those particles etc.
However in all calculations the temperature drops as a result of a change in volume. Regardless of which time period your discussing. The exception to that rule is if new interactions occur from new particles coming into measurable existence. Oft termed az freezing into existence in some high energy particle physics textbooks
Does the idea of 'absolute hot' make sense?
Ryan, you're hijacking your own thread here. And no it doesn't.
FAQ: A thermal expansion coefficient of spacetime?
1. What is a thermal expansion coefficient of spacetime?
A thermal expansion coefficient of spacetime is a measure of how much spacetime expands or contracts in response to changes in temperature. It is similar to the concept of thermal expansion in materials, where an increase in temperature causes the material to expand.
2. How is the thermal expansion coefficient of spacetime measured?
The thermal expansion coefficient of spacetime is measured by observing the changes in the fabric of spacetime in response to changes in temperature. This can be done through experiments and observations of celestial bodies and their movements.
3. What factors can affect the thermal expansion coefficient of spacetime?
The thermal expansion coefficient of spacetime can be affected by various factors such as the mass and energy density of the universe, the distribution of matter and energy, and the presence of gravitational waves.
4. What are the implications of a high thermal expansion coefficient of spacetime?
A high thermal expansion coefficient of spacetime could indicate that the universe is expanding at an accelerated rate, which could have significant implications for our understanding of the origins and fate of the universe.
5. Can the thermal expansion coefficient of spacetime change over time?
Yes, the thermal expansion coefficient of spacetime can change over time as the universe evolves and its properties change. This is why ongoing research and observations are crucial in understanding the nature of spacetime and its expansion.
