A transverse wave traveling through a medium versus a particle of the medium
In a transverse wave, particles of the medium oscillate vertically without any horizontal movement in the direction of wave propagation. The total vertical distance traveled by a particle over one minute can be calculated based on the amplitude and frequency of the wave. While it may seem misleading to say a particle travels one wave cycle, it is accurate if understood as oscillation perpendicular to wave direction, with net displacement returning to zero after each cycle. In real-world scenarios, such as water waves, particles may exhibit both transverse and longitudinal motion due to the medium's movement. Understanding these dynamics clarifies the behavior of particles in different types of waves.
User1265
A transverse wave travelling through a medium has a frequency of 5.0 Hz, a wavelength of
4.0 cm and an amplitude of 3.0 cm.
What is the total distance travelled by a particle of the medium in one minute?
I imagine a particle traveling across 1 wave cycle. The total vertical distance traveled across the wave cycle is 4 x the amplitude of the wave. The total vertical distance traveled in 1 minute:
5 cycles in 1 second, thus 5x60 cycles in a minute
then 4 x amplitudes effectively traveled per wave cycle = 4 x 3cm = 12cm distance traveled vertically per wave cycle
total distance traveled (vertically) by particle in the medium for a minute = 12 x 5x60 = 12x300 = 3600cm
The question I have is : Q1 The particle travels the wave - as the wave progresses through the medium, so why is it that the particle only travels in the vertical direction (ocsillating up and down) but we do not calculate the horizontal distance the particle travels (in the direction of the wave propagation) ?
Q2 Does a particle of a medium travel any horizontal distance/ in the direction of wave propagation at all if a wave progresses through the particle/ through the medium?
Q3 If it is true that a particle of a medium does not progress in the horizontal direction / the direction the wave propagates in a medium, then is it wrong to think of the particle traveling 1 wave cycle?
Q4 Is it better to think of a particle of fixed horizontal coordinate,moving up and down as a wave (of 1 cycle) progresses through the medium/and particle?
User1265 said:
Homework Statement:: A transverse wave traveling through a medium has a frequency of 5.0 Hz, a wavelength of
What is the total distance traveled by a particle of the medium in one minute?
Your answer to the original question shows a good understanding. To help you with your 4 questions...
Q1 The particle travels the wave - as the wave progresses through the medium, so why is it that the particle only travels in the vertical direction (oscillating up and down) but we do not calculate the horizontal distance the particle travels (in the direction of the wave propagation)?
For a transverse wave traveling horizontally there is no horizontal movement. Think how a ‘Mexican wave’ works in a football crowd. Watch this animation:
https://gifimage.net/transverse-wave-animation-gif-4/
and follow a red dot.
Q2 Does a particle of a medium travel any horizontal distance in the direction of wave propagation at all if a wave progresses through the particle/ through the medium?
No. Same as Q1.
And you can’t say a wave travels 'through the particle'. A wave is a moving pattern of the particles.
But if the medium is moving (e.g. a water wave on the surface a flowing river) the particles are obviously also moving along with the medium (because the medium IS the collection of particles).
It could be misleading. But it is not wrong, providing that ‘travelling’ is understood to refer to motion in the direction perpendicular to the direction of propagation. But the particle’s displacement is zero after each cycle.
Q4 Is it better to think of a particle of fixed horizontal coordinate, moving up and down as a wave (of 1 cycle) progresses through the medium/and particle?
It is clearer – it accurately describes what happens in a (horizontal) transverse wave.
Other notes:
The direction of propagation doesn’t have to be horizontal. But whatever the direction is, in a transverse wave the particles oscillate perpendicular to it.
For longitudinal waves, particles oscillate backwards and forwards parallel to the direction of propagation. But each particle is still back at its initial position after each cycle..
Waves don’t have to consist of patterns created by oscillating particles. In an electromagnetic wave (which is transverse) it is the electric and magnetic fields that oscillate, but this is harder to visualise.
Likes User1265 and Delta2
It certainly can. See e.g. Fig 4.18 at https://manoa.hawaii.edu/exploringourfluidearth/physical/waves/wave-energy-and-wave-changes-depth.
If I generate a wave in a rope, the rope barely changes length, so the motions of individual elements of the rope must involve some longitudinal component.
Good point. The OP should note that in such real-world cases we're dealing with a combination of transverse and longitudinal waves, as opposed to a 'perfect' (ideal) transverse wave.
No. Same as Q1.
Other notes:
Thanks this is really helpful!
Likes Steve4Physics
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
