A Trick to Memorizing Trig Special Angle Values Table
  • Thread starter Thread starter benorin
    Angle Table Trig
Memorizing trigonometric special angle values is crucial for calculus, as evaluations often involve these angles. A suggested method is to create a table with angles in both degrees and radians, filling in sine, cosine, and tangent values systematically. The sine function starts at zero and follows a pattern based on the square roots of integers divided by four. Understanding the unit circle and basic triangle geometry aids in deriving these values. This approach simplifies learning and retention of essential trigonometric functions.
benorin
Insights Author
In calculus classes when you are asked to evaluate a trig function at a specific angle, it’s 99.9% of the time at one of the so-called special angles we use in our chart. Since you are likely to have learned degrees first I’ll include degree angles in the first chart, but after that, it’s going to be radian only.
Begin by setting up the table on scratch paper as follows:
$$\begin{array}{ l| |c|c|c|c|c } \theta & 0 = 0º & \tfrac{\pi}{6} = 30º & \tfrac{\pi}{4}=45º & \tfrac{\pi}{3}=60º & \tfrac{\pi}{2}=90º \\ \hline\hline \sin\theta &   &   &  &   &    \\ \hline \cos\theta &   &    &    &    &    \\ \hline \tan\theta &    &    &    &   &    \\ \hline \end{array} $$
Then remember ##\sin\theta## starts at zero, fill in the pattern
$$\begin{array}{ l| |c|c|c|c|c } \theta & 0 & \tfrac{\pi}{6} & \tfrac{\pi}{4} & \tfrac{\pi}{3} & \tfrac{\pi}{2} \\ \hline\hline\sin\theta & \tfrac{\sqrt{0}}{2} & \tfrac{\sqrt{1}}{2} & \tfrac{\sqrt{2}}{2} & \tfrac{\sqrt{3}}{2} & \tfrac{\sqrt{4}}{2} \\...
Continue reading...
Likes yucheng, sysprog, Wrichik Basu and 4 others
I think I'll make this compulsory reading for my Maths students!
Likes symbolipoint, benorin and Greg Bernhardt
In our junior classes, we learned it in a similar way:
##\theta~\rightarrow##​
0° = 0​
30° = ##\dfrac{\pi}{6}##​
45° = ##\dfrac{\pi}{4}##​
60° = ##\dfrac{\pi}{3}##​
90° = ##\dfrac{\pi}{2}##​
##\sin \theta##​
##\sqrt{\dfrac{0}{4}}##​
##\sqrt{\dfrac{1}{4}}##​
##\sqrt{\dfrac{2}{4}}##​
##\sqrt{\dfrac{3}{4}}##​
##\sqrt{\dfrac{4}{4}}##​
##\cos \theta##​
##\tan \theta##​
##\sqrt{\dfrac{0}{4 - 0}}##​
##\sqrt{\dfrac{1}{4 - 1}}##​
##\sqrt{\dfrac{2}{4 - 2}}##​
##\sqrt{\dfrac{3}{4 - 3}}##​
##\sqrt{\dfrac{4}{4 - 4}}##​
Likes bublik_c_makom and benorin
"Trick"? The very basics of triangle Geometry and the Pythagorean Theorem, and The UNIT CIRCLE.
Easily enough done, drawing a Unit Circle and judging Sines and Cosines, and whichever other of the functions to derive what you need. Degree measures 30, 45, 60, 0, and 90, and 180 are the easy ones and are commonly used "Reference" angles.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
