A variational problem with the constraint that the function be decreasing
In summary, the conversation discusses a mathematical problem involving a constant and a set of decreasing functions. The goal is to find the maximal value of a function L, defined on the set, and the conversation also poses a special and general question regarding this value.
Lennart Stern
The problem is in the attached document. Thanks for any suggestions!
Lennart
  • A variational problem with the constraint that the function be decreasing.pdf
The mathematical problem:
$\theta$ is a constant that equals 0.8.
We consider the set
'$ S=\left\{(F,h):F is a decreasing function from R^{+} to R^{+}, h\in R, 0=1- \frac{\theta+1)}{\theta} \frac {(\int^{h}_{y=0} F(y) dy)}{/F(0)} \frac{F(0)-\frac{1}{2}}{F(0)-F(h)} \right\}$'
The function L is defined on S by
$ L(F,h)= \frac{\int^{h}_{x=0} \int^{h}_{y=x} F(y) dy dx} {\int^{h}_{x=0} \int^{h}_{y=0} F(y) dy dx} h$
We want to find the maximal value of L.
A further problem:
Denote by $L(\theta)$ the maximal value of L. What is $max_{\theta \in (0,1)} \frac {L(\theta)}{\theta}$ ?
We consider the set
A further problem:
If you want LaTeX to be readable in this forum, you need to remove the $ delimiters and enclose your commands between "[tex ]" and "[/tex ]" delimiters (no space after the word tex--I used a space so as to not confuse the system). For example, here is one of your formulas (justa copied and pasted between the delimiters I:
[tex] L(F,h)= \frac{\int^{h}_{x=0} \int^{h}_{y=x} F(y) dy dx} {\int^{h}_{x=0} \int^{h}_{y=0} F(y) dy dx} h[/tex]
RGV
[tex]\theta[/tex] is a positive constant.
We consider the set
[tex] S=\left\{(F,h):F is a decreasing function from R^{+} to R^{+}, h\in R, 0=1- \frac{\theta+1}{\theta} \frac {\int^{h}_{y=0} F(y) dy}{F(0)} \frac{F(0)-\frac{1}{2}F(h)}{F(0)-F(h)} \right\}[/tex]
We want to find the maximal value of L, denoted by [tex]L(\theta)[/tex].
A special question:
What is L(0.8) ?
A general question:
What is [tex]max_{\theta \in (0,1)} \frac {L(\theta)}{\theta}[/tex] ?
Related to A variational problem with the constraint that the function be decreasing
1. What is a variational problem with the constraint of decreasing function?
A variational problem with the constraint of decreasing function is a type of optimization problem where the goal is to find the function that minimizes a certain quantity, subject to the condition that the function must be decreasing. In other words, the function must have a negative slope.
2. How is a variational problem with the constraint of decreasing function different from a standard optimization problem?
A variational problem with the constraint of decreasing function is different from a standard optimization problem in that it adds an additional condition or constraint for the function to meet. This constraint makes the problem more challenging and may require different techniques to solve.
3. What are some real-world applications of a variational problem with the constraint of decreasing function?
A variational problem with the constraint of decreasing function has many applications in fields such as economics, physics, and engineering. For example, in economics, it can be used to model demand curves, while in physics, it can be used to describe the motion of a falling object.
4. How is the solution to a variational problem with the constraint of decreasing function determined?
The solution to a variational problem with the constraint of decreasing function is typically determined using the Euler-Lagrange equation, which is a mathematical formula that finds the function that minimizes the given quantity while satisfying the constraint of being decreasing.
5. Can a variational problem with the constraint of decreasing function have multiple solutions?
Yes, a variational problem with the constraint of decreasing function can have multiple solutions. However, in most cases, there is a unique solution that is the global minimum. In some cases, there may be multiple local minima, but only one global minimum that meets the constraint.
  • Classical Physics
  • Mechanical Engineering
