A vehicle of mass 1200 kg accelerates
In summary: The student has attempted to solve for x in terms of u and v, but has apparently gotten stuck. I'm not sure what x is supposed to be solving for, or what the relevance of 37.5 is.
NotVerySmart
Member reminded to use the formatting template for all homework help requests
[/B]
Hi All,
I submitted some homework in for marking & received back that on my last question (iii) I had worked out 37.5 wrong, could someone please have a look at my working & advise on where I am making the error.
I'm not sure if the tutor means 37.5 at 1 or 3.
I assume 3 as it says I have questions (i) & (ii) correct.
Kind Regards
A vehicle of mass 1200 kg accelerates uniformly from rest to a velocity of
15 m/s in 5 seconds. It continues at this velocity for 15 seconds before decelerating uniformly at a rate of 5m/s2 to rest. Determine the following:
(i)The acceleration
(ii)The time taken to decelerate from 15 m/s to rest
(iii)The total distance travelled
Hello NVS, :welcome:
Still having trouble to make decent use of thte template eh ? Look at few other threads.
Your tutor has been very kind. I, for one would have striped (1) too: it's not ##\ \ ## 15 m/s - 0 / 5s ##\ \ ## but ##\ \ ## (15 m/s - 0 m/s) / 5s ##\ \ ## and the result is 3 m/s2 and not 3 m/s
In part (ii) you did OK
Part (iii) must have an error: if at the start you need 5 sec and at the end only 3, the distances covered must be different. Check both !
Is the distance covered 15^2 + 0^2 x 5x2 = 225m?
Or do you need to divide 225 by 2 = 112.5m?
Show your work. It is no fun looking at a bunch of numbers and multiplication signs and trying to figure out what the student has in mind.
The distance covered can be divided into three sections: Distance traveled while accelerating, distance traveled while moving uniformly and distance traveled while decelerating. Show your calculations and explain your calculations for each of the three phases. Then add them up.
Sorry it was the above question at the top of the page, I have the same question needing help with. But I'll try your method. Thanks.
I see the question. I see the purported answer: "15^2 + 0^2 x 5x2 = 225m?"
What I do not see is any explanation for why those numbers would be relevant to the question. Squinting and trying to read the hand-written image, I see a claim that distance traveled while accelerating is equal to ##S=\frac{1}{2}(u+v)##. It is not clear what S, u or v are supposed to be. That equation is followed by a claim that ##\frac{1}{2}(u+v) = 37.5##
Related to A vehicle of mass 1200 kg accelerates
1. What is the formula for calculating acceleration?
The formula for acceleration is a = F/m, where a is the acceleration, F is the net force acting on the object, and m is the mass of the object.
2. How do you calculate the acceleration of a 1200 kg vehicle?
To calculate the acceleration of a 1200 kg vehicle, you need to know the net force acting on the vehicle. Once you have the net force, you can divide it by the mass of the vehicle (1200 kg) to find the acceleration.
3. What is the unit of measurement for acceleration?
The unit of measurement for acceleration is meters per second squared (m/s^2).
4. Can an object have a negative acceleration?
Yes, an object can have a negative acceleration if it is slowing down or moving in the opposite direction of the net force acting on it.
5. How does the mass of a vehicle affect its acceleration?
The mass of a vehicle directly affects its acceleration. The greater the mass of the vehicle, the harder it is to accelerate. This is because a greater force is needed to move a larger mass at the same rate as a smaller mass.
