A very Simple angular movement numerical
In summary, the conversation is about a prototype car engine flywheel being tested. The angular position of the flywheel is given by a formula and the diameter is provided. The conversation then goes on to ask about finding the distance a particle on the rim moves, the angle at certain times, the average angular velocity, and the instantaneous angular velocity. It is mentioned that the person asking for help must provide an attempt at solving the problem or a description of where they are stuck.
sunjava1
Hi I don't have idea about solving it, If anyone can give me a descriptive answer or solve it for me, it'll be appreciable
The flywheel of a prototype car engine is under test. The angular position θ of the flywheel is given by θ = (3.0rad/s3)t3 and the diameter of the flywheel is 36cm.
(a)Find the distance that a particle on the rim moves during that time interval.
(b) Find the angle θ, in radians and in degree, at times t1 = 3.0s and t2 = 6.0s.
(c) Find the average angular velocity, in rad/s and in rev/min, between t1 = 3s and t2 = 6s.
(d) Find the instantaneous angular velocity at time t1 = 3.0s and t2 = 6.0s.
Sunjava1, we don't do your homework for you here, we can only help you towards your own solutions. To that end, you must provide an attempt to solve the problem or at least a description of your attempt and where you've become stuck. That is why the posting software provides a template...
Related to A very Simple angular movement numerical
1. What is angular movement?
Angular movement is the rotation or circular motion of an object around a fixed point. It is typically measured in degrees or radians.
2. What is a simple angular movement numerical?
A simple angular movement numerical refers to a basic calculation that involves the measurement of angular movement, such as finding the angular displacement or angular velocity of an object.
3. How is angular movement measured?
Angular movement is typically measured in degrees or radians using tools such as protractors or by calculating the ratio of the arc length to the radius of a circle.
4. What is the difference between angular displacement and angular velocity?
Angular displacement refers to the change in the orientation or position of an object with respect to a reference point, while angular velocity is the rate of change of angular displacement over time.
5. How is angular movement used in science?
Angular movement is used in various fields of science, such as physics and engineering, to study the rotation and movement of objects. It is also important in understanding the motion of celestial bodies and the mechanics of machines and vehicles.
15K
