MHB Abby's question at Yahoo Answers involving exponential decay
Abby's question revolves around understanding the time constant T in the context of exponential decay, specifically how it relates to the tangent line of the function r(t)/r0 at the point (0,1). The solution begins with the exponential decay formula r(t) = r0e^(-kt) and establishes that T can be derived by setting r0/e = r0e^(-kT), leading to T = 1/k. The slope of the tangent line at t=0 is calculated as -k, resulting in the equation of the tangent line being y = 1 - kt. Ultimately, the intersection of this tangent line with the t-axis confirms that T is indeed the time constant, as required.
MarkFL
MHB
Here is Abby's question:
Differential Equations time constant problem? The time constant T is the amount of time that an exponentially decaying quantity takes to decay by a factor of 1/e. Given an exponentially decaying quantity r(t) with the initial value r0 = r(0), show that its time constant is the time at which the tangent line to the graph of r(t)/r0 at (0,1) crosses the t-axis.
Please help! I can't figure this out. Please explain your steps so I can understand for future questions. Thank you!
Here is a link to the original question:
Differential Equations time constant problem? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Abby,
Let's begin with:
$\displaystyle r(t)=r_0e^{-kt}$ where $\displaystyle 0<k$
Now, to determine the time constant $\displaystyle T$ as defined, we may set:
$\displaystyle \frac{r_0}{e}=r_0e^{-kT}$
We now solve for $\displaystyle T$:
$\displaystyle e=e^{kT}$
Equating exponents, we find:
$\displaystyle kT=1\,\therefore\,T=\frac{1}{k}$
Next, let's determine the root of the described tangent line.
$\displaystyle \frac{r(t)}{r_0}=e^{-kt}$
Hence, the slope of the tangent line is:
$\displaystyle \frac{d}{dt}\left( e^{-kt} \right)=-ke^{-kt}$
At $\displaystyle t=0$ this gives us a slope of $\displaystyle m=-k$
Then, using the point-slope formula, we find the equation of the tangent line to be:
$\displaystyle y-1=-k(t-0)$
$\displaystyle y=1-kt$
And so the root is:
$\displaystyle t=\frac{1}{k}=T$
Shown as desired.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
