Aberration of Light in Circular Motion: Does Distance Change?
In summary, the Ehrenfest Paradox is a problem in quantum mechanics that is caused when two particles are observed simultaneously.
Phylosopher
139
TL;DR Summary
What happens to distance?
Simple as it sounds!
Usually people derive aberration of light using linear motion, not circular motion. When aberration happens in linear motion, one would expect distance between the source and the observer to change. But, in circular motion, the path light takes in the circular motion, in the source frame of reference is ##r##.
Thus, I would expect distance in the frame of reference of the moving object to be ##r## as well!
The motion is perpendicular to ##r##, speed of light is fixed, yet we have time dilation! therefore traveled distance is elongated!
What am I missing? Does distance change?
I don't understand your scenario. Is this about time dilation for uniform circular motion?
Likes Phylosopher
Phylosopher said:
Summary: What happens to distance?
Thus, I would expect distance in the frame of reference of the moving object to be rrr as well!
There are many different rotating reference frames, which one are you using?
Likes Phylosopher
Let me clarify.
Problem:
Take a reference frame S, it represents the reference frame of a point source (say a star). In this reference frame, the distance between the orbiting object and the source is ##r##. Further, the object have a perfect circular orbit and so ##r## is constant and the speed of the object ##v## is perpendicular to ##r##.
In the reference frame of the circulating object ##S'##, the star have a velocity ##v## and is titled with an angle ##\theta## due to aberration of light.
In the reference frame of the object ##S'##, what is the distance ##r'## between the source and the object?
My attempt:
My intuition says that ##r=r'## since the velocity ##v## is perpendicular to ##r## in the reference frame of the source ##S##. Also, if I want to define r in this reference frame, then I would write ##r=c \Delta t##, where ##Delta t## is the time it takes light to travel from the center to the rim of the circle.
From another point of view, in the reference frame ##S'## time dilation must occur no matter the direction of velocity. Therefore, ##\Delta t'=\gamma \Delta t##. Speed of light is fixed ##c##. If I want to know how long it takes light to travel from the source to the object in ##S'##, then I would find it as follows ##r'= c\Delta t'=c \gamma \Delta t= \gamma r##.
Phylosopher said:
Let me clarify.
Problem:
My attempt:
S' is not an inertial frame. The basic equations of time dilation and length contraction (and the Lorentz transformation in general) apply only to inertial reference frames.
You need a more complex analysis for S'.
Likes Phylosopher
Phylosopher said:
In the reference frame of the object S′S′S', what is the distance r′r′r' between the source and the object?
Which version of the reference frame of the object? There are several.
You need to either provide the metric in the rotating frame or the transformation from the inertial frame to the rotating frame (or both) before your question can be answered. The answer depends on your arbitrary choice of coordinates
Don't say that LOL.
I am actually aware of this! I was hoping that someone can lead me to a simpler answer.
A momentarily co-moving frame.
Months ago, I was reading research papers on Ehrenfest Paradox, and I was seriously annoyed with it. Not because it is hard, but because it made a clear distinction for me between linear and rotational motion.
Anyway, in the vicinity of ##\beta <<1##, can I assume that ##r'\approx r##?
I would really appreciate it if anyone can suggest for me papers/books in this specific subject. I am also interested in rotation around extended sources (a sphere instead of a point), but I couldn't find anything on it.
Ok, which moment do you want the momentarily co-moving frame to be co-moving?
Note that the momentarily comoving frame is an inertial frame, not a rotating frame. So I am not sure why it is relevant, but we certainly can use it to answer.
at ##t## I guess! Since I should be an observer in ##S##.
Hmm, looking at your posts above ##t## appears to be a coordinate, not a moment. I may be misunderstanding your ##t## above.
Look, this is getting irritating. You have asked an ambiguous question and I have told you what we need to resolve the ambiguity and 9 posts later the same ambiguity remains.
You need to define the reference frame clearly. Actually write down the transformation you are interested in or provide enough information for us to do so. This back and forth is annoying.
If you don’t care about your question enough to clarify it as repeatedly requested then we will just close the thread. If it is not important to you then it doesn’t need to clutter up the site.
My first reaction to the thread title is that aberration in SR has nothing whatsoever to do with distance. It has only to do with how angles between velocities transform from one frame to another.
If you are interested in distance in rotating frames, I'd suggest forgetting for the time being about aberration, and doing some research on the concept of distance in rotating frames first.
The cliff notes version is that radial distances are fairly intuitive in rotating frames, but the transverse distances (for instance, computing the circumference of a circle in a rotating frame) are not.
For more specifics - in general, the topic is called the Ehrenfest pardox. There's a vast and confusing literature on the topic, unfortunately. I don't have a guide as to which particular papers have high impact, and which are nonsense, unfortunately.
I do like Ruggieo's "The Relative space: space measurements on a rotating platform". https://arxiv.org/abs/gr-qc/0309020, though I can't necessarily claim it has a high impact factor, but I like the way it applies the fundamental SI defintion of distance via round-trip travel times to rotating frames.
The basic idea is that space-time is 4-dimenstional, and that distances are 3-dimensional, so we need to project the 4-dimensional space-time onto a 3-dimensional space to measure distances. Ruggiero paper basically addresses the nature of the "space" defined by such a projection operation.
Likes Phylosopher
FAQ: Aberration of Light in Circular Motion: Does Distance Change?
What is aberration of light in circular motion?
Aberration of light in circular motion refers to the apparent change in the direction of light rays due to the motion of the observer. This phenomenon was first observed by astronomer James Bradley in the 18th century.
How does distance affect aberration of light in circular motion?
The distance between the observer and the object being observed does not affect the aberration of light in circular motion. However, the speed of the observer's motion does have an impact on the amount of aberration observed.
What is the cause of aberration of light in circular motion?
The cause of aberration of light in circular motion is the combination of the finite speed of light and the motion of the observer. As the observer moves, the light rays appear to be coming from a different direction due to the time it takes for the light to reach the observer.
How is aberration of light in circular motion related to the speed of light?
The speed of light plays a crucial role in aberration of light in circular motion. The faster the observer is moving, the greater the angle of aberration will be. This is because the observer is covering a larger distance in the same amount of time, causing a greater shift in the apparent direction of the light rays.
Is aberration of light in circular motion a significant factor in everyday life?
No, aberration of light in circular motion is not a significant factor in everyday life. It is only noticeable when the observer is moving at a very high speed, such as in the case of astronomical observations. In most cases, the effect is too small to be perceived by the human eye.
