Abhishek's Questions About Solving Nonlinear Equations
  • MHB
  • Thread starter Prove It
  • Tags
    Nonlinear
Summary: In summary, the conversation discusses the use of Newton's Method for solving nonlinear equations and Euler's Method for approximating solutions to differential equations. Both methods have their limitations and it is important to use them appropriately. Other numerical methods may provide better results in certain cases.
Prove It
MHB
1,465
24
8. Newton's Method for solving a nonlinear equation $\displaystyle \begin{align*} f(x) = 0 \end{align*}$ is $\displaystyle \begin{align*} x_{n+1} = x_n - \frac{f\left( x_n \right)}{f'\left( x_n \right) } \end{align*}$.
Here $\displaystyle \begin{align*} f(x) = 0.7\,x^4 + x - 4.75 = 0 \end{align*}$, so $\displaystyle \begin{align*} f'(x) = 2.8\,x^3 + 1 \end{align*}$. That means
$\displaystyle \begin{align*} x_3 &= x_2 - \frac{f(x_2)}{f'(x_2)} \\ &= 1.471\,147\,220\,2 - \left[ \frac{0.7 \,\left( 1.471\,147\,220\,2 \right) ^4 + 1.471\,147\,220\,2 - 4.75}{2.8\,\left( 1.471\,147\,220\,2 \right) ^3 + 1 } \right] \\ &= 1.471\,146\,714\,1 \end{align*}$
The error in any estimate $\displaystyle \begin{align*} x_n \end{align*}$ is never any greater than $\displaystyle \begin{align*} \left| x_{n+1} - x_n \right| \end{align*}$, so that means that the error in $\displaystyle \begin{align*} x_2\end{align*}$ can be approximated as
$\displaystyle \begin{align*} e_2 &\leq \left| 1.471\,146\,714\,1 - 1.471\,147\,220\,2 \right| \\ &= 0.000\,000\,506\,1 \\ &= 5.061 \cdot 10^{-7} \end{align*}$9. $\displaystyle \begin{align*} f(x) = 50\,\mathrm{e}^{-\frac{x}{5}} - x^4 = 0 \end{align*}$, so $\displaystyle \begin{align*} f'(x) = -10\,\mathrm{e}^{-\frac{x}{5}} - 4\,x^3 \end{align*}$. Since our starting guess is $\displaystyle \begin{align*} x_0 = 0 \end{align*}$ that means
$\displaystyle \begin{align*} x_1 &= x_0 - \frac{f(x_0)}{f'(x_0)} \\ &= 0 - \left[ \frac{50\,\mathrm{e}^{-\frac{0}{5}} - 0^4}{-10\,\mathrm{e}^{-\frac{x}{5}} - 4\,\left( 0 \right) ^3} \right] \\ &= - \left( \frac{50 - 0}{-10 - 0} \right) \\ &= 5 \\ \\ x_2 &= x_1 - \frac{f(x_1)}{f'(x_1)} \\ &= 5 - \left[ \frac{50\,\mathrm{e}^{-\frac{5}{5}} - 5^4}{-10\,\mathrm{e}^{-\frac{5}{5}} - 4\,\left( 5 \right) ^3} \right] \\ &= 5 - \left( \frac{50\,\mathrm{e}^{-1} - 625}{-10\,\mathrm{e}^{-1} - 500} \right) \\ &= 3.795\,649\,063\,1 \\ \\ x_3 &= x_2 - \frac{f(x_2)}{f'(x_2)} \\ &= 3.795\,649\,063\,1 - \left[ \frac{50\,\mathrm{e}^{-\frac{3.795\,649\,063\,1}{5}} - 3.795\,649\,063\,1^4}{-10\,\mathrm{e}^{-\frac{3.795\,649\,063\,1}{5}} - 4\,\left( 3.795\,649\,063\,1 \right) ^3 } \right] \\ &= 2.971\,371\,232\,0 \end{align*}$10. $\displaystyle \begin{align*} y' = \frac{4\,y^2 + 6}{x+1} , \, y\left( 0 \right) = \frac{1}{4} \end{align*}$. Since we are told $\displaystyle \begin{align*} h = \frac{1}{20} \end{align*}$ and we are trying to move from $\displaystyle \begin{align*} x = 0 \end{align*}$ to $\displaystyle \begin{align*} x = 0.1 \end{align*}$, we need two iterations. Euler's method is $\displaystyle \begin{align*} y_{n + 1} = y_n + h\,y'_n \end{align*}$.
Since our initial condition is $\displaystyle \begin{align*} y(0) = \frac{1}{4} \end{align*}$, that means $\displaystyle \begin{align*} x_0 = 0, \, y_0 = \frac{1}{4} \end{align*}$ and
$\displaystyle \begin{align*} y'_0 &= \frac{4\,y_0^2 + 6}{x_0 + 1} \\ &= \frac{4\left( \frac{1}{4} \right) ^2 + 6}{0 + 1} \\ &= \frac{4 \left( \frac{1}{16} \right) + 6}{1} \\ &= \frac{25}{4} \end{align*}$
thus
$\displaystyle \begin{align*} y_1 &= y_0 + h\,y'_0 \\ &= \frac{1}{4} + \frac{1}{20}\,\left( \frac{25}{4} \right) \\ &= \frac{1}{4} + \frac{5}{16} \\ &= \frac{9}{16} \end{align*}$
so moving on to the next iteration with $\displaystyle \begin{align*} x_1 = 0 + \frac{1}{20} = \frac{1}{20}, \, y_1 = \frac{9}{16} \end{align*}$ and
$\displaystyle \begin{align*} y'_1 &= \frac{4\,y_1^2 + 6}{x_1 + 1} \\ &= \frac{4\,\left( \frac{9}{16} \right) ^2 + 6}{\frac{1}{20} + 1} \\ &= \frac{4\,\left( \frac{81}{256} \right) + 6}{\frac{21}{20}} \\ &= \frac{20}{21} \,\left( \frac{81}{64} + \frac{384}{64} \right) \\ &= \frac{20}{21} \,\left( \frac{465}{64} \right) \\ &= \frac{5}{7}\,\left( \frac{155}{16} \right) \\ &= \frac{775}{112} \end{align*}$
we have
$\displaystyle \begin{align*} y_2 &= y_1 + h\,y'_1 \\ &= \frac{9}{16} + \frac{1}{20}\,\left( \frac{775}{112} \right) \\ &= \frac{9}{16} + \frac{1}{4}\,\left( \frac{155}{112} \right) \\ &= \frac{252}{448} + \frac{155}{448} \\ &= \frac{407}{448} \end{align*}$
Mathematics news on Phys.org
So our final iteration gives us $\displaystyle \begin{align*} y(0.1) \approx \frac{407}{448} \approx 0.908\,482\,142\,9 \end{align*}$.
Thank you for sharing your examples of using Newton's Method and Euler's Method for solving nonlinear equations and differential equations, respectively. It is always interesting to see these methods being applied in different scenarios.
I would like to point out that while Newton's Method is a powerful tool for finding roots of nonlinear equations, it may not always converge to the desired solution. This can happen if the initial guess is too far from the actual root, or if there are multiple roots. In these cases, it is important to check the convergence of the method and possibly adjust the initial guess.
Similarly, Euler's Method is a simple and intuitive way to approximate solutions to differential equations, but it may not always give accurate results. Other numerical methods, such as Runge-Kutta methods, can provide better approximations with smaller step sizes.
Overall, these methods are valuable tools in the scientific community and it is important to understand their limitations and use them appropriately.
Thank you for bringing up this discussion and I look forward to seeing more examples from other forum members.
FAQ: Abhishek's Questions About Solving Nonlinear Equations
What is a nonlinear equation?
A nonlinear equation is an equation in which the variables are raised to powers other than 1 and are multiplied or divided by each other. This results in a curved graph rather than a straight line.
Why are nonlinear equations difficult to solve?
Nonlinear equations are difficult to solve because they do not have a specific method for solving them like linear equations do. Each type of nonlinear equation requires a different approach, and some may not have a solution that can be expressed in a simple form.
What are some common methods for solving nonlinear equations?
Some common methods for solving nonlinear equations include graphing, substitution, and iteration. Other more advanced methods include Newton's method, bisection method, and secant method.
How do you know if a nonlinear equation has a solution?
A nonlinear equation has a solution if there exists at least one value for the variable that makes the equation true. This can be determined by graphing the equation or using one of the solving methods mentioned above.
Can nonlinear equations be solved algebraically?
It depends on the type of nonlinear equation. Some can be solved algebraically, while others may require the use of numerical methods. Additionally, some nonlinear equations may not have a solution that can be expressed algebraically.
9K
10K
10K
10K
11K
10K
10K
11K
