About a root in the topic of automorphism and fixed field. HELP
In summary, the conversation discusses the concept of automorphisms and fixed fields in the context of a primitive m-th root of unity. It is known that if an automorphism fixes the elements in a certain field, then it must also fix the elements in any subfield. The conversation also mentions the relevant equation \mathbb{Q}(\xi) = \mathbb{Q}(\xi^i) for any i with \gcd(i,m)=1 . However, the challenge lies in proving that \gcd (i,m) = 1 . The conversation also mentions using the Isomorphism Extension Theorem, but it does not seem to work. Ultimately, it is shown that if \gcd(i
julypraise
110
About a root in the topic of automorphism and fixed field. HELP!
Let [itex] m [/itex] be a positive integer.
Let [itex] \xi = \exp (2pi/m) [/itex]. Then [itex] \xi [/itex] is a primitive m-th root of unity. (I.e., [itex] \xi [/itex] is a solution of
[itex] \Phi_{m}(X):=(X^m - 1)/(X-1) [/itex].)
If [itex] \phi \in \mbox{G}(\mathbb{Q}(\xi)/\mathbb{Q}) [/itex], i.e., [itex] \phi [/itex] is an automorphism of [itex]\mathbb{Q}(\xi)[/itex] fixing the elements in [itex]\mathbb{Q}[/itex], then [itex] \phi (\xi) = \xi^i [/itex] for some [itex] i [/itex] with [itex] \gcd (i,m) = 1[/itex]
[itex] \mathbb{Q}(\xi) = \mathbb{Q}(\xi^i)[/itex] for any [itex] i [/itex] with [itex] \gcd(i,m)=1 [/itex] but not with [itex] i [/itex] such that [itex] \gcd(i,m) \neq 1 [/itex]
I know the above relevant equation holds. And also I know that [itex] \phi(\xi) = \xi^i [/itex] for some integer [itex] i [/itex] but I cannot prove [itex] \gcd (i,m) = 1 [/itex]. I've tried to use Isomorphism Extension Theorem, but not really works.
Can someone help me to prove this statement? Proof: Let \phi \in \mbox{G}(\mathbb{Q}(\xi)/\mathbb{Q}) , i.e., \phi is an automorphism of \mathbb{Q}(\xi) fixing the elements in \mathbb{Q} such that \phi (\xi) = \xi^i for some integer i . Let \gcd (i,m) \neq 1 . We will show that \mathbb{Q}(\xi) \neq \mathbb{Q}(\xi^i) . Since \gcd (i,m) \neq 1 , there exist nonzero integers a, b such that ai-bm = 0 . Since \xi^m = 1 , it follows that \xi^{ai-bm} = 1 .Now, \xi^i = \phi(\xi) \neq \xi^{ai-bm} = 1 , so \mathbb{Q}(\xi) \neq \mathbb{Q}(\xi^i) . This contradiction implies that \gcd (i,m) = 1 , as desired.
FAQ: About a root in the topic of automorphism and fixed field. HELP
What is an automorphism in the context of mathematics?
An automorphism is a type of mathematical function that preserves the structure and properties of a mathematical object. In other words, it is a mapping that takes an object and produces an equivalent object.
How does an automorphism relate to fixed fields?
An automorphism is closely related to fixed fields because it maps elements in a field to other elements in the same field. This means that the fixed field of an automorphism is the set of all elements that remain unchanged under the automorphism.
Can you give an example of an automorphism and its fixed field?
One example of an automorphism is the identity function, which maps every element in a field to itself. In this case, the fixed field would be the entire field since all elements remain unchanged.
What is the significance of automorphism in mathematics?
Automorphisms play a significant role in many areas of mathematics, including group theory, ring theory, and algebraic geometry. They are important for studying the symmetries and structure of mathematical objects.
How are automorphisms used in practical applications?
Automorphisms have practical applications in fields such as computer science and cryptography. They are used to create secure encryption algorithms and to analyze the properties of data structures and algorithms.
