MHB About a variant of the Chinese Remainder Theorem
The discussion revolves around the Chinese Remainder Theorem, specifically addressing two key points. First, it establishes that a system of congruences has a solution if the remainders are congruent modulo the greatest common divisor of the moduli. Second, it seeks to prove that any two solutions to the system are congruent modulo the least common multiple of the moduli. The conversation includes a detailed exploration of the mathematical proof for part (ii), involving the relationships between the integers and their prime factorizations. The notation for the multiplicative inverse in modular arithmetic is clarified, emphasizing its relevance in the context of the theorem.
steenis
Let $m$ and $m'$ be positive integers, and $d=gcm(m,m')$.
(i) The system:
$x \equiv b (mod \ m)$
$x \equiv b' (mod \ m')$
has a solution if and only if $b \equiv b' (mod \ d)$
(ii) two solutions of the system are congruent $mod \ l$, where $l = lcm(m,m')$.
I can prove part (i), but can anyone help me with part (ii) ?
Remember $gcd(a,b) \cdot lcm(a,b) = a \cdot b$
See, for instance: "Cuoco - Learning Modern Algebra (2013)", p.145 and p.148
Example:
$x \equiv 1 (mod \ 6)$ and $x \equiv 4 (mod \ 15)$
Then $m=6$, $m'=15$, $d=3$, $b=1$, $b'=4$, and $1 \equiv 4 (mod \ 3)$, so (i) applies:
$19 \equiv 1 (mod \ 6)$ and $19 \equiv 4 (mod \ 15)$.
$lcm(6,15)=30$ and all the solutions are: $\cdots \ -41,-11,19,49,79 \ \cdots$.
Mathematics news on Phys.org
Hi, steenis.
Start with two solutions, say $x$ and $y$, to the system. We want to show that $l$ divides $x-y$. Since $x$ and $y$ solve the system of congruences, we have that $m$ and $m'$ divide $x-y$, which can be seen by writing $x-y = (x-b)-(y-b)$. Since $m$ and $m'$ both divide $x-y$, so too must their least common multiple, $l$, which can be proved by considering the prime factorizations of $m$ and $m'$.
(i) The system:
Hi steenis,
Suppose $\gcd(m,m')=d$, then we can write $m=qd$ and $m'=q'd$ with $\gcd(q,q')=1$.
And suppose $b\equiv b' \pmod d$, so that $\frac{b'-b}d$ is an integer.
Then we have:
$$x = b + km = b' + k'm' \quad\Rightarrow\quad
b + kqd = b' + k'q'd \quad\Rightarrow\quad
kq = \frac{b'-b}d + k'q' \\ \quad\Rightarrow\quad
kq \equiv \frac{b'-b}d \pmod {q'} \quad\Rightarrow\quad
k \equiv [q]_{q'}^{-1} \frac{b'-b}d \pmod {q'} \quad\Rightarrow\quad
k = [q]_{q'}^{-1} \frac{b'-b}d + k''q' \\ \quad\Rightarrow\quad
x= b + km= b + \left([q]_{q'}^{-1} \frac{b'-b}d + k''q'\right)qd = b + [q]_{q'}^{-1}q (b'-b) + k''qq'd
Thus:
$$x \equiv b + [q]_{q'}^{-1}q (b'-b) \pmod{\text{lcm}(m,m')}$$
Btw, note that in the second step we have $b + kqd = b' + k'q'd \quad\Rightarrow\quad (b-b') = (k'q' - kq)d$.
Since the right hand side is divisible by $d$, so must the left hand side be divisible by $d$, proving (i).
Thank you, both, very helpful.
However, what does $[q]_{q'}^{-1}$ mean?
The multiplicative inverse of q with respect to q'.
That is, it is such that:
$$[q]_{q'}^{-1} \cdot q \equiv 1 \pmod {q'}$$
And since $q$ and $q'$ are co-prime that inverse is guaranteed to exist and to be unique.
As an example $[2]_5^{-1} = [3]_5$ because $3\cdot 2 \equiv 1 \pmod 5$.
It's a common notation to express solutions that make use of the Chinese Remainder Theorem.
Note that the general solution of $x\equiv a_i \pmod{m_i}$ with $m_i$ pairwise coprime, is $x\equiv\sum a_i \left[\frac M{m_i}\right]_{m_i}^{-1} \frac M{m_i} \pmod M$, where $M=\prod m_i$.
Clear, thank you.
I think my texts are too introductory to come across this notation.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
