About Bernoulli's equation for fluid flow
In summary, the conversation discusses the concept of Bernoulli's equation and its application to fluid flow in a horizontal hose. It is determined that in an ideal flow, there is no need for a pressure gradient to sustain a flow, while in a real flow, a pressure gradient is necessary to balance the viscous shear stress and maintain a constant flow rate. The conversation also mentions the role of friction in causing pressure loss in real world situations and the need for a circulating pump in a closed loop system. It is noted that Bernoulli's equation does not apply without modification in a viscous flow.
samy4408
62
Hello, I am currently studiying Bernoulli's equation and I have trubble understanding something , say we have a horizontal hose (no change in altitude of pressure ) Bernoulli's equation state that an ideal fluid can flow thought the hose with the same velocity , does an ideal fluid need a pressure gradient to flow thought this hose ?
Yes.
Lnewqban said:
Yes.
it does ? so we have a change in pressure between two points in the hose, so the velocity is not constant ?
No. Continuity demands that velocity be constant because there's nowhere else for the water to go.
Note, with the standard/ideal Bernoulli equation there is no loss, but in the real world there is (due to friction).
Likes samy4408 and Lnewqban
that makes sense thanks a lot!
Likes russ_watters and Lnewqban
That energy consumed by friction comes from the internal energy of the fluid in the way of static pressure, since the flow remains constant and height does not change.
If you could measure velocity and static pressure between two distant points, you would see that the value of velocity remains the same, but the value of static pressure downstream is lower than the one upstream.
Please, see:
https://www.tec-science.com/mechanics/gases-and-liquids/pressure-loss-in-pipe-systems/
That is the reason for the need of a circulating pump in a closed loop of constant height: you need to increase the pressure of the fluid between the end and the beginning of the loop by transferring mechanical energy from the pump into the fluid.
Likes russ_watters
Please, see:
That's only true in a viscous flow. Bernoulli's equation does not apply in that situation without modification for viscous losses.
In a truly ideal flow, you do not need a pressure gradient to sustain a flow. Applying a pressure gradient to an ideal flow results in acceleration.
In a real (viscous) flow, you need a pressure gradient that exactly balances the viscous shear stress to maintain a constant flow rate.
Likes cjl and Lnewqban
FAQ: About Bernoulli's equation for fluid flow
What is Bernoulli's equation for fluid flow?
Bernoulli's equation is a fundamental principle in fluid mechanics that relates the pressure, velocity, and elevation of a fluid in a closed system. It states that the sum of the kinetic energy, potential energy, and pressure energy of a fluid remains constant along a streamline.
How is Bernoulli's equation derived?
Bernoulli's equation can be derived from the principles of conservation of mass, momentum, and energy. It involves simplifying the Navier-Stokes equations, which describe the motion of fluids, and applying the assumptions of steady, incompressible, and inviscid flow.
What are the applications of Bernoulli's equation?
Bernoulli's equation has many practical applications in engineering and everyday life. It is used to calculate the lift and drag forces on an airplane wing, the flow rate in a pipe, and the pressure in a venturi meter. It also explains the phenomenon of lift in airfoils and the functioning of carburetors.
What are the limitations of Bernoulli's equation?
Bernoulli's equation is based on several assumptions, such as steady, incompressible, and inviscid flow, which may not hold true in all situations. It also does not take into account factors such as turbulence, viscosity, and compressibility, which can significantly affect the behavior of fluids.
How is Bernoulli's equation related to the conservation of energy?
Bernoulli's equation is a manifestation of the principle of conservation of energy, which states that energy cannot be created or destroyed, only transferred or converted from one form to another. In the case of fluid flow, the total energy of the fluid remains constant, but it can be converted between different forms, such as kinetic, potential, and pressure energy.
