A About calculating a fundamental group
aalma
What is the way to compute ##\pi_1(PGL_2(R))##?
Is it related to defining an action of ##PGL_2(R)## on ##S^3##?
it would be helpful if you can provide me with relevant information regarding this
There is a bundle ##\mathbb{R}^\times\to GL_n(\mathbb{R})\to PGL_n(\mathbb{R})## where ##\mathbb{R}^\times## is the subgroup of nonzero scalar matrices. The identity component of the fiber is contractible, so ##PGL_n(\mathbb{R})## and ##GL_n(\mathbb{R})## has the same homotopy groups in positive degrees, and also the identity component of ##GL_n(\mathbb{R})## is homotopy equivalent to ##SO(n;\mathbb{R})## by performing Gram-Schmidt on the columns.
So in this case, ##\pi_1(PGL_2(\mathbb{R}))\cong\pi_1(SO(2;\mathbb{R}))\cong \pi_1(S^1)\cong\mathbb{Z}.##
Likes malawi_glenn, Euge and aalma
Is the idea here to move from the fibration you first mentioned to a long exact sequence, knowing that ##\pi_0(GL_2(R))=\pi_0(SO_2(R))##?
When saying "The identity component of the fiber is contractible" to what fiber are you referring and then you mean that ##\pi_1(GL_2(R))=\pi_1(PGL_2(R))##?
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
