About lagrange dynamics of aparticle
In summary, the Lagrange equation for a particle in a constrained environment will result in the forces of constraint not being included explicitly, but they will be there implicitly.
marxist_ad
hi all ,
i am new at this forum , so i don't exactly know the rules about the topics and their sorting
i am self studying lagrange dynamics.
so my question is : when writing lagrange equations for aparticle ,& the particle
is in conformity with the constraints ; why the generalized forces
arenot containing the constraint forces ?
thanks in advance.
Are you asking why the forces of constraint are not there in the equations explicitly?
Remember that for holonomic constraints, the number of independent generalized co-ordinates in the Lagrange's equation is less by the number of constraints from the actual number of co-ordinates. The equations contain the forces of constraint implicitly.
how do i know that equations contain constraints explicity or implicity?
my question in other words :
why the constraint forces arenot included in the generalized forces resulted from applying lagrange equations on aparticle is in conformity with the constraints ?
The whole technique of the Lagrangian treatment was developed so as to eliminate our calculating the forces of constraint.
Consider a simple example: a frictionless bead is moving on a frictionless wire in a plane in absence of gravity. The force of constraint would be the normal reaction of the wire directed radially inward, which would be equal to the centripetal force. That's how you would solve it to get the equations of motion, and show that it is moving with uniform linear and angular speed.
Now, why don't you do this very simple problem using Lagrange's equation yourself? You'll get a feel of what's happening.
Note that only one independent generalized co-ordinate theta is required. The fact that r is a constant, (or sqrt(x^2+y^2)) takes care of the normal reaction. The physical force of constraint, viz. the normal reaction, is equivalent to the equation r=constant.
thanks , you are the man .
FAQ: About lagrange dynamics of aparticle
What is Lagrange dynamics?
Lagrange dynamics is a mathematical framework used to describe the motion of a particle or system of particles. It is based on the principle of least action, which states that the path a particle takes between two points is the one that minimizes the action, or the difference between the kinetic and potential energies.
What is the difference between Lagrange dynamics and Newtonian dynamics?
The main difference between Lagrange dynamics and Newtonian dynamics is the approach used to describe the motion of a particle. While Newtonian dynamics uses force as the fundamental quantity, Lagrange dynamics uses energy and generalized coordinates. This makes Lagrange dynamics more general and applicable to a wider range of systems.
What are the advantages of using Lagrange dynamics?
One advantage of using Lagrange dynamics is that it simplifies the equations of motion for a system. It also allows for the use of generalized coordinates, which can make solving problems easier. Additionally, Lagrange dynamics can be applied to systems with constraints, which makes it useful in many different fields of science and engineering.
What are the limitations of Lagrange dynamics?
Lagrange dynamics is not applicable to systems with non-conservative forces, such as friction or air resistance. It also cannot account for the effects of relativity or quantum mechanics. In addition, it can be more mathematically complex and difficult to apply compared to Newtonian dynamics in certain situations.
How is Lagrange dynamics used in real-world applications?
Lagrange dynamics is used in a variety of fields, including physics, engineering, and robotics. It has been applied to study the motion of celestial bodies, analyze the stability of mechanical systems, and design control systems for spacecraft and robots. It is also used in computer simulations to model the behavior of physical systems.
