About magnet field in solid oxydes fuel cells
In summary: The block ions move in the solid electrolyte regardless of the external load and magnetic field. In summary, SOFCs use oxygen ions to generate electricity through a chemical reaction, and do not require an external current source. They do not involve any magnetism and the EMF is not affected by the external load or magnetic field.
gravl4
Hello!
I don't understand one easy moment in high temp solid oxydes fuel cells (SOFC):
1. Oxygen ions are moving always via solid electrolite ZrO2? SOFC without load and SOFC in short circuit modes. (High temp is default mean)
2. Electrolises process need electric energy and external current source must do EMF (electromotive force) anytime.
SOFC use hidrogen chemical energy and oxydation process can be without current in output circuit. External load set optimal efficient point on output characteristics. Do I think right?
3. Is Magnet field around solid electrolite always? When load exchange from 0 to short circuit. How magnet field do depend with load?
4. Perhaps do EMF about 1V block ions move in solid electrolite for load 0 and field is 0 to?
Thank you for any help!
1. Yes, oxygen ions are always moving through the solid electrolyte in a SOFC. 2. The electrolysis process does not require an external current source to generate EMF; it produces its own EMF due to the difference in chemical potential between the two electrodes. When an external load is applied, it alters the output characteristics of the cell, setting an optimal efficiency point. Your understanding is correct.3. A magnetic field is not generated in a SOFC. The design of a SOFC does not involve any magnetism. 4. The EMF in a SOFC is generated due to the difference in chemical potential between the two electrodes. It has nothing to do with the ions or the external load.
Related to About magnet field in solid oxydes fuel cells
1. What is a magnet field in solid oxydes fuel cells?
A magnet field in solid oxydes fuel cells refers to the presence of a magnetic field within the cell that affects the transport of ions and electrons. This magnetic field is usually generated by the movement of charged particles within the cell.
2. How does the magnet field affect the performance of solid oxydes fuel cells?
The magnet field can affect the performance of solid oxydes fuel cells in several ways. It can alter the movement of ions and electrons, change the distribution of reactants within the cell, and influence the chemical reactions taking place. This can ultimately impact the cell's efficiency and power output.
3. Can the magnet field be controlled in solid oxydes fuel cells?
Yes, the magnet field can be controlled in solid oxydes fuel cells. Various methods such as applying an external magnetic field or using magnetic materials within the cell can be used to manipulate and control the strength and direction of the magnet field.
4. What are the potential applications of magnet fields in solid oxydes fuel cells?
Magnet fields have the potential to improve the performance and efficiency of solid oxydes fuel cells. They can also be used for sensing and monitoring the cell's operation and can aid in the development of new and advanced fuel cell technologies.
5. Are there any limitations or challenges in studying magnet fields in solid oxydes fuel cells?
Yes, there are some limitations and challenges in studying magnet fields in solid oxydes fuel cells. The field is relatively new, and there is still much to be understood about its effects on the cell's performance. Additionally, the complex nature of fuel cell systems can make it challenging to isolate and study the specific effects of the magnet field.
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
