About output characterstics of a npn transistor in CE configuration
In summary, the behavior of a transistor in different states can be understood by considering the biasing of the base-collector junction and its effect on the current in the output circuit. In the saturated state, increasing the voltage across the collector-emitter will increase the current in the output circuit due to the negative temperature coefficient of the base-collector junction. In the cut-off state, there is no current flow through the base-collector junction and thus no current in the output circuit. In the active state, increasing the input current causes an increase in the current through the base-collector junction, resulting in an increase in the output current.
keep@science
Q1.when transistor[NPN transistor in CE configuration] is in saturated state ,then,in output characteristic curve on increasing voltage across collector -emitter,the current in the output circuit increases linearly but my confusion is that we know that in saturation state transistor's base -collector junction is forward biased ; on increasing collector emitter voltage there is no effect on base-emitter voltage but it increases voltage across base collector such that it opposes the forward bias condition so, according to my view it should decrease the current in the output circuit.
Q2.when transistor is in cut off state , the input voltage is zero and in output characteristic
curve it is shown that current in the output circuit should also be zero whatever the value of collector base voltage;but according to my view due to low potential at input circuit and high at output circuit the current should flow from input circuit to output through collector base junction in reverse bias condition and there should be a current in output circuit.
Q3.why in active state of transistor output current for a fixed value of collector emitter voltage,increases on increasing current in input circuit?
A1. In the saturated state of a NPN transistor, the base-collector junction is forward biased, so increasing the voltage across the collector-emitter will increase the current in the output circuit. This is because the base-collector junction has a negative temperature coefficient, meaning that as the voltage across the collector-emitter increases, the current flowing through the base-collector junction also increases and this causes the current in the output circuit to increase. A2. In the cut-off state, the input voltage is zero and the base-collector junction is reverse biased. As such, the current in the output circuit should be zero regardless of the value of the collector-base voltage. This is because there is no current flowing through the base-collector junction and therefore no current can flow from the input to the output circuit. A3. In the active state, the transistor is operating in the linear region and the output current for a fixed value of collector-emitter voltage increases with increasing input current. This is because increasing the input current causes an increase in the current flowing through the base-collector junction and therefore an increase in the current flowing through the output circuit.
Related to About output characterstics of a npn transistor in CE configuration
1. What is a NPN transistor in CE configuration?
A NPN transistor in CE configuration refers to a type of transistor that has three layers of alternating N-type and P-type semiconductor material. The Collector (C) and Emitter (E) are connected to the outer layers while the Base (B) is connected to the middle layer. This type of configuration is commonly used in amplifying circuits.
2. What are the output characteristics of a NPN transistor in CE configuration?
The output characteristics of a NPN transistor in CE configuration describe how the output current (Ic) varies with the input voltage (Vce) while keeping the input current (Ib) constant. These characteristics typically show a linear relationship between Ic and Vce, with a constant Ib value.
3. How do the output characteristics of a NPN transistor in CE configuration differ from other configurations?
The output characteristics of a NPN transistor in CE configuration differ from other configurations, such as CB (Common Base) and CC (Common Collector), in terms of the input and output voltage and current relationships. In CE configuration, the input current is controlled by the base-emitter current (Ib) while the output current is controlled by the base-collector voltage (Vbc). In CB configuration, the input current is controlled by the base-collector current (Ic) while the output current is controlled by the base-emitter voltage (Vbe). In CC configuration, the input voltage is controlled by the base-emitter voltage (Vbe) while the output voltage is controlled by the collector-emitter current (Ic).
4. What factors affect the output characteristics of a NPN transistor in CE configuration?
The output characteristics of a NPN transistor in CE configuration can be affected by various factors, such as the doping levels of the different semiconductor layers, the temperature, and the biasing conditions (i.e. the applied voltages). Additionally, the physical dimensions and material properties of the transistor can also have an impact on the output characteristics.
5. How are the output characteristics of a NPN transistor in CE configuration useful?
The output characteristics of a NPN transistor in CE configuration are useful in understanding the behavior of the transistor in different operating conditions. They can also be used to determine the operating point (Q-point) of the transistor, which is important in designing and analyzing transistor circuits. Additionally, these characteristics can also help in troubleshooting and identifying any potential issues with the transistor circuit.
  • Electrical Engineering
  • Other Physics Topics
