About pair production using light
In summary: I'm not sure that two photons could produce more than one electron-positron pair. I suspect that you can only get one electron-positron pair per pair of photons.And similarly in the case of pair production from a single photon where the interaction involves additionally an atom or molecule.It's essentially the same process. It's just that in the case involving a nucleus, the second photon is a virtual photon from the interaction of the photon with the nucleus.
wasong
TL;DR Summary
Can light make two pairs? (assuming enough energy to make two pairs)
If so, why?
If so, why? or If not, why not?
Welcome to PF.
Two pairs of what?
Likes Vanadium 50
Baluncore said:
Welcome to PF.
Two pairs of what?
Thank you~ (electron+electron+positron+positron)!
Whence these pairs?
PeroK said:
Whence these pairs?
I don't understand. What's mean "Whence"?
PeroK said:
Whence: from what place, source or cause.
https://www.merriam-webster.com/dictionary/whence
in a book: Electromagnetic waves (with enough energy) = γe− + e+
in my opinion: Electromagnetic waves (with enough energy) = γe− + e+ that's right! or Electromagnetic waves (with enough energy) = γe− + e− + e+ + e+ also that's right! because There's no problem if you keep Conservation of energy and conservation of charge.
wasong said:
in a book
That is NOT a proper citation on this forum. You might as well say "some guy on a bus told me".
Likes Vanadium 50
Sorry.. The book is Concepts of Modern Physics. I was not good at English and citation.
Likes phinds
This pair production can only take place in the presence of an atom of molecule - which is required to balance momentum. I don't know why precisely only one pair may be produced - I'm sure someone will answer that - but it's not enough just to say that energy and momentum are conserved. There must be a possible interaction between the photon and the atom that produces two pairs.
You probably mean "photon," not electromagnetic waves. Pair production is one of the basic processes in QED, and it's actually ##\gamma + \gamma \to e^- + e^+##. There are probably higher-order processes which can produce multiple electron-positron pairs from a single pair of photons, but it's much less likely to occur. And, of course, if you start with multiple pairs of photons, each could produce an electron-positron pair.
Does the word "less likely" mean that there is a possibility of it happening? from a single pair of photons
If the answer to my question is yes, where can I find the relevant concept or data?
This is a different process: this is pair production from a pair of photons. It's the reverse of pair annhililation.
An electron-positron pair can annhililate and produce an even number of photons; but, I'm not sure that two photons could produce more than one electron-positron pair. I suspect that you can only get one electron-positron pair per pair of photons.
An electron-positron pair can annihilate and produce an even number of photons; but, I'm not sure that two photons could produce more than one electron-positron pair. I suspect that you can only get one electron-positron pair per pair of photons.
It's been a long time since I studied particle physics, but I'll say I think it's possible though I'd expect it to be really unlikely. For example, the neutral pion can decay into two photons, and it can also decay into two electron-positron pairs. So conceivably, two photons could produce a pion, which is simply the reverse of the first decay I mentioned, that then decays into two electrons and two positrons. At the least, this hypothetical scenario suggests no conservation laws are broken which would invalidate the process of two photons producing two pairs.
The simplest scenario which might work is two photons coupling to separate electron-positron pairs and then then one particle from one pair exchanges a virtual photon with a particle from the second pair so that momentum and energy are conserved.
FAQ: About pair production using light
What is pair production using light?
Pair production using light is a phenomenon in which a high-energy photon (light particle) interacts with an atomic nucleus, producing an electron and a positron (antimatter particle). This process requires a minimum energy of 1.02 MeV, which is equivalent to the mass of the electron and positron combined.
How does pair production using light occur?
Pair production using light occurs when a high-energy photon interacts with an atomic nucleus. The photon must have enough energy to overcome the mass of the electron and positron, and the excess energy is converted into the kinetic energy of the particles. This process follows the law of conservation of energy and mass, where the total energy and mass before and after the interaction must be equal.
What is the significance of pair production using light?
Pair production using light is significant because it provides evidence for the existence of antimatter. It also allows scientists to study the properties of antimatter, which is important for understanding the fundamental laws of physics. Additionally, pair production is used in medical imaging techniques such as PET scans.
Can pair production using light occur in a vacuum?
Yes, pair production using light can occur in a vacuum. In fact, it is more likely to occur in a vacuum because there are no particles to interact with the created electron and positron, causing them to quickly annihilate each other. This phenomenon is known as vacuum polarization.
What are the potential applications of pair production using light?
Aside from its use in medical imaging, pair production using light has potential applications in particle accelerators, where it can produce high-energy particles for research purposes. It is also being studied for potential use in energy production, as the annihilation of matter and antimatter produces a large amount of energy. However, the technology for controlling and harnessing antimatter is still in its early stages of development.
