About permutation acting on the Identity matrix
In summary, permutation acting on the identity matrix involves rearranging its rows or columns according to a specified permutation. The identity matrix, which has 1s on the diagonal and 0s elsewhere, serves as a foundational structure in linear algebra. When a permutation is applied, it results in a new matrix where the positions of the 1s are changed according to the permutation's mapping, while 0s remain in their original positions. This process illustrates the relationship between permutations and matrix representations, emphasizing how permutations can transform matrices while preserving their fundamental properties.
aalma
46
Question:
Let ##\sigma\in S_n## be a permutation and ##T_{\sigma}## be the matrix we obtain from ##I## by appling ##\sigma## on the raws of ##I## (I.e ##\sigma## acts on the rows of ##I##) . Then:
1. ##\det(T_{\sigma}) = sgn(\sigma) ##
and 2. ##T_{\sigma} T_{\tau} =T_{\sigma\circ \tau}##, for all ##\sigma, \tau \in S_n##.
For the first part, I know that each permutation Can be written as a product of transpositions.
For ##\sigma\in S_n## either it is even (it's signature = 1) or odd (it's signature = - 1). And here I think $T_{\sigma}$ would be equal to ##(-1)^r * det(I)=(-1)^r## depend on how many transpositions we have in the product.
Now, how to connect these things togeter correctly?
The other part seems some how trivial, but what is the formal explanation of this equality?
Look at the general definition of the determinant of a matrix.
What is determinant ?
It is the sum that goes though all permutation of indices {1,2,3,...,n} of the quadratic matrix ( all n! of them)
$$det(A)
\begin{vmatrix}
a_{1,1} & a_{1,2} & \cdots & a_{1,n} \\
a_{2,1} & a_{2,2} & \cdots & a_{2,n} \\
\vdots & ~ & \ddots & \vdots \\
a_{n,1} & a_{n,2} & \cdots & a_{n,n}
\end{vmatrix}
\sum_{\sigma \in S_n} sign(\sigma) \cdot a_{1,\sigma(1)} \cdot a_{2,\sigma(2)} \cdot a_{3,\sigma(3)} \dots a_{n,\sigma(n)}$$
[1 method]
For ##T_{\sigma}##, the sum have n! members but only one is different from zero.
For all other permutations at least one of ##a_{1,\sigma(1)} \cdot a_{2,\sigma(2)} \cdot a_{3,\sigma(3)} \dots a_{n,\sigma(n)}## is zero and then all product is zero.
$$det(T_{\sigma})
det(\sigma(
\begin{vmatrix}
1 & 0 & \cdots & 0 \\
0 & 1 & \cdots & 0 \\
0 & 0 & \cdots & 1
\end{vmatrix}
= sign(\sigma) \cdot 1 \cdot 1 \cdot 1 \dots 1
= sign(\sigma)
You do not have to worry about number of transpositions in a permutation.
It is already "built in" in the determinant definition (formula)
## sign(\sigma)=(-1)^{tr(\sigma)}##, where ##tr(\sigma)## is the number of transpositions ( swapping places )
That is one method
[2 method]
Another method cold be ... usage of the fact that , if you swap two rows of the matrix its determinant will swap the sign either from plus to minus or from minus to plus.
Now you start swapping rows of the matrix ##I## in order to get matrix ##T_{\sigma}##
In the first column of the matrix ##T_{\sigma}##, where is the number 1 ? (in all other rows of that column are 0s )
If "1" is in the first row do not swap any rows and determinant stays 1. Go to the next column.
If number "1" is not in the same (first) row swap first row and that row so that number "1" from the first column goes to his place in the first column of the ##T_{\sigma}## matrix.
In the 2nd column of the matrix ##T_{\sigma}##, where is the number 1?
If "1" is in the 2nd row all is fine . Go to the next column.
If number "1" is not in the same (2nd) row swap 2nd row and that row so that number "1" from the 2nd column goes to his place in the 2nd column of the ##T_{\sigma}## matrix.
And so on until last (n-th) column of the matrix .
det(T_{\sigma})
= det(I) \cdot (-1)^{tr(\sigma)}
=sign(\sigma)
Where ##tr(\sigma)## is number of swaps of rows of the matrix. (= the transpositions of the permutation)
Likes aalma
$$det(A)
\begin{vmatrix}
\end{vmatrix}
[1 method]
$$det(T_{\sigma})
det(\sigma(
\begin{vmatrix}
0 & 0 & \cdots & 1
\end{vmatrix}
= sign(\sigma)
That is one method
[2 method]
det(T_{\sigma})
=sign(\sigma)
Thanks! In the first part, I am still confused of what ##a_{1,\sigma(1)}## and so on represent (are they the entries of ##I## after appling ##\sigma## and so the product of the ##a_{i, \sigma(i)}## is not zero just when ##\sigma=id##?
In the other part, Can I say that
##T_{\sigma} T_{\tau}=\sigma(I) \tau(I)## and
##T_{\sigma \circ\tau} =(\sigma \circ \tau) (I)## so the equality follows from the definition of composition of permutations?
Yes, but also is true for ##T_\tau## so the product of the ##a_{i, \sigma(i)} ...## is not zero just when ##\sigma=\tau##
For example , you have 3x3 matrices
The identity or (Leopold) Kronecker delta matrix
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
and permutation
##\sigma : (1,2,3) \mapsto (2,1,3)##
meaning
##\sigma(1)=2##
##\sigma(2)=1##
##\sigma(3)=3##
The corresponding ##T_{\sigma}## matrix is
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
Now you want to calculate ##det(T_{\sigma})##. We have to go trough all 6 permutations of indices (1,2,3) and add the products
##(1,2,3) \Rightarrow (-1)^0 \cdot a_{1,1} \cdot a_{2,2} \cdot a_{3,3} = 0 \cdot 0 \cdot 1 =0##
2,3 swap ...
##(1,3,2) \Rightarrow (-1)^1 \cdot a_{1,1} \cdot a_{2,3} \cdot a_{3,2} = - 0 \cdot 0 \cdot 0=0##
1,2 swap ...
##(2,3,1) \Rightarrow (-1)^2 \cdot a_{1,2} \cdot a_{2,3} \cdot a_{3,1} = 1 \cdot 0 \cdot 0=0##
3,1 swap ...
##(2,1,3) \Rightarrow (-1)^3 \cdot a_{1,2} \cdot a_{2,1} \cdot a_{3,3} = - 1 \cdot 1 \cdot 1=-1##
2,3 swap ...
##(3,1,2) \Rightarrow (-1)^4 \cdot a_{1,3} \cdot a_{2,1} \cdot a_{3,2} = 0 \cdot 1 \cdot 0=0##
1,2 swap ...
##(3,2,1) \Rightarrow (-1)^5 \cdot a_{1,3} \cdot a_{2,2} \cdot a_{3,1} = - 0 \cdot 0 \cdot 0=0##
The sum is ##det(T_{\sigma})=-1##
Yes, that is it ... That is just yet another method to calculate the same thing
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
If you swap the first and the second row ...
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
Just one swap ##det(T_{\sigma})=(-1)^1 det(I)=-1##
Likes aalma
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
and permutation
meaning
##\sigma(1)=2##
##\sigma(2)=1##
##\sigma(3)=3##
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
2,3 swap ...
1,2 swap ...
3,1 swap ...
2,3 swap ...
1,2 swap ...
The sum is ##det(T_{\sigma})=-1##Yes, that is it ... That is just yet another method to calculate the same thing
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
Just to make sure, i think there is some confusion in the calculations in the example of ##S_3##?
##T_{\sigma}T_{\tau}## is a product of two matries and equals to the matrix ##T_{\sigma\circ tau}##, right? Now again though it is clear, what is the way to show it formally? Is what was already shownn (in the first part useful here)?
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
and permutation
meaning
##\sigma(1)=2##
##\sigma(2)=1##
##\sigma(3)=3##
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
2,3 swap ...
1,2 swap ...
3,1 swap ...
2,3 swap ...
1,2 swap ...
##I=
\begin{vmatrix}
1 & 0 & 0 \\
0 & 1& 0 \\
0 & 0 & 1
\end{vmatrix}
##T_{\sigma}=
\begin{vmatrix}
0 & 1 & 0 \\
1 & 0& 0 \\
0 & 0 & 1
\end{vmatrix}
Can you please take a look on the previous comment
Just try with two 3x3 matrices ##T_{\sigma}, T_{\tau}## and check what you will get (##T_{\sigma \circ \tau}## or something else)
Check also with either permutation of columns or rows . All formulas are produces the same result if you swap rows and columns .
Likes aalma
I think it's actually easier to prove these multiply the way you want if you think of these as functions, not matrices.
##T_\sigma : (x_1,...,x_n)\to (x_{\sigma(1)},...,x_{\sigma(n)})##
