About probability of playing roulette
In summary, the author of a book about statistics and probability explains the use of central limit theorem using roulette as an example. He mentions that for an ordinary roulette wheel with 38 numbers, the chance of getting 17 is 1/38. However, for an extremely warped wheel, the chance of getting 17 will be increased. To determine if a wheel is warped, one must account for chance variation by computing the standard deviation and using the central limit theorem. It is necessary to observe about 2000 spins to effectively rule out chance variation, and if the three-SD range of an extremely warped wheel does not overlap with the three-SD range of an ordinary wheel, then the number of occurrences of 17 can confidently be used
KFC
488
Hi there,
I am reading a book about statistics and probability. In one chapter, the author use roulette as an example to explain the use of central limit theorem. He says for ordinary roulette, there are 38 numbers (including one 0 and 00). The chance of occurrance of 17 is 1/38. But for a wrapped wheel (assume extreme warp in section 17), the change of getting 17 will be increased. So statistically, how to tell if a wheel is wrapped? The following is excerpted from the book
In order to such a decision you must account for chance variation. One way to do this is by computing the standard deviation and using the central limit theorem.It turns out that even for this extremely warped wheel you need to observe about 2000 spins to get enough separation to effectively rule out change. In 2000 spins, the three-SD (three times of standard deviation) range around the average number of 17's for the warped wheel (average=105.26; 3SD=29.96) does not overlap the three-SD range for an ordinary wheel (average=52.63; 3SD=21.48). In other words, the number of occurrences of 17 with this extremely warped wheel will most likely be outside the three SD range of an ordinary wheel, so you could confidently rule out chance variance.
Sorry for the long information. Here are what I confuse
1) Why we have to rule out the "chance variation"? My opinion is to make sure the biased outcome of roulette is because of the wrap not because the chance, is that right?
2) I don't understand why the author say because of no overlap of two normal distribution, we could confidently rule out chance variance? How to understand that? What happen if two curves do overlap?
Mathematics news on Phys.org
I'm not really sure what you mean by a wrapped wheel, but let's take a look at the rest of the post:
Imagine I have two coins. I flip one and it comes up heads. I flip another one and it comes up tails. "Look!" I cry. "I have two different coins; one gives heads when flipped, the other gives tails."
You probably agree that would be a silly leap of faith from a single coin flip. We have to account for chance variation because things that take values randomly are supposed to be different, even if they have the same distribution. So you can't just say that two sequences of events are different so must be controlled by different distributions - instead you have to show in some way that they are so different that they cannot be controlled by the same distribution.
In this case we consider one sequence which is spinning a normal wheel, and another one spinning a wrapped wheel. By measuring how often 17 comes up, it turns out that the number of occurrences is different enough between the two wheels that we can confidently say which wheel it is based on how often 17 comes up (remember, we could be wrong! The sequence of spins that we get could look like it comes from the wrapped wheel, but simply be a low probability sequence from the unwrapped wheel)
The normal curves are always going to overlap because they're non-zero everywhere, but the part within 3 standard deviations of the mean don't overlap. Since it is unlikely for the number of 17's to lie more than three standard deviations from the average number of 17's this means that with high probability we can pick the right type of wheel based on the number of 17's.
If the two parts of the curve did overlap, we would have a much harder time deciding which wheel it was, especially if the number of 17's landed somewhere in the overlap
Try to be consistent in your description of the roulette wheel. You have described it as "wrapped" in four places and "warped" in four places.
I think you mean "warped" so that the wheel is not consistently flat. "Wrapped" and "warped" are entirely different words.
Related to About probability of playing roulette
1. What is the probability of winning at roulette?
The probability of winning at roulette depends on the type of bet you place. For example, the probability of winning on a straight bet is 1 in 38 (or 2.63%), while the probability of winning on an even/odd or red/black bet is 18 in 38 (or 47.37%). Overall, the house has an advantage in roulette, so the probability of winning is always less than 50%.
2. Does the previous outcome in roulette affect the probability of the next spin?
No, the previous outcome in roulette has no impact on the probability of the next spin. Each spin of the roulette wheel is an independent event, meaning the outcome of one spin does not affect the outcome of the next spin.
3. Is there a strategy that can improve the probability of winning at roulette?
No, there is no strategy that can guarantee a win in roulette. The game is based on chance and the house always has an advantage. Some players may choose to use betting systems or strategies, but these do not affect the overall probability of winning.
4. What is the difference between American and European roulette in terms of probability?
The main difference between American and European roulette is the number of pockets on the wheel. American roulette has 38 pockets, including a double zero, while European roulette has 37 pockets, with only a single zero. This means that the probability of winning is slightly higher in European roulette, as the house edge is lower.
5. Is there a way to calculate the probability of certain outcomes in roulette?
Yes, the probability of certain outcomes in roulette can be calculated using basic probability principles. For example, the probability of winning on a straight bet is 1/38, or 2.63%. However, the overall probability of winning at roulette is more complex and involves considering the different types of bets and the house edge.
  • Beyond the Standard Models
