I About Reversible vs Irreversible Gas Compression and Expansion Work
The discussion focuses on the application of Newton's third law to gas compression and expansion involving a massless piston. It clarifies that the external pressure applied to the piston is equal to the thermodynamic pressure of the gas at the piston interface. The conversation highlights the importance of including viscous normal stress in irreversible processes. Additionally, there are corrections regarding figures and terminology in the referenced work on gas work. The participants express appreciation for the clarity and engagement in the discussion.
cianfa72
Hi,
reading the interesting Reversible vs Irreversible Gas Compression and Expansion Work insight by @Chestermiller I would like to ask for clarification on some points.
In the second bullet at the beginning
Since, by Newton’s third law, the external force per unit area exerted by the surroundings on the gas is equal to the gas thermodynamic pressure at the interface P.
my understanding is as follows: consider an ideal gas contained in a cylinder featuring a massless piston. An external force per unit area ##P_{ext}## is applied to the piston through a bunch of (external) bodies.
Applying the Newton's third laws to the massless piston we get two things:
  • the force per unit area the piston applies to the external bodies through the piston's outer edge is the same (in module) as the external force per unit area ##P_{ext}##
  • the force per unit area the thermodynamic pressure of the gas at the piston's inner edge ##P_I## (i.e. the thermodynamic pressure ##P_I## at the piston internal interface) applies to the piston is the same (in module) as the force the piston applies per unit area on the gas inside the cylinder
The above hold since otherwise the acceleration of the massless piston would be infinite.
Does it make sense ? Thank you.
Science news on Phys.org
cianfa72 said:
Hi,
Yes it does make sense. But, in the way that I define things, I would consider ##P_{ext}## to be the force per unit area that the inside face of the piston applies to the gas. Otherwise, based on the way you have defined ##P_{ext}##, I would have to include the piston as part of the system. Of course, in this situation it doesn't matter, but, if the piston had mass and thermal inertia, by my way of doing things, the piston would have to be included as part of the system.
Also, I should mention that, if the process is irreversible, the force per unit area applied by the gas to the inside face of the piston would conceptually have to include the viscous normal stress.
Yes, definitely.
Of course, as you explained in the 'Spring-Damper Model Analysis' and 'Ideal Gas Analysis' sections.
Likes Chestermiller
cianfa72 said:
Yes, definitely.Of course, as you explained in the 'Spring-Damper Model Analysis' and 'Ideal Gas Analysis' sections.
You are wonderful. I hope that you continue to stay involved with Physics Forums. It's so nice to encounter someone like you who is on the same wavelength as I.
By the way: in the insight I do not see 'Figure 8 Work Done By Viscous Stresses on Piston' and the sentence
Fig. 9 shows a plot of the ratio of the irreversible work to the reversible work ##W_{Irr} / W_R## for the case of an ideal gas as a function of the expansion/compression volume ratio ##W_f / W_i##
should actually read:
Fig. 9 shows a plot of the ratio of the irreversible work to the reversible work ##W_{Irr} / W_R## for the case of an ideal gas as a function of the expansion/compression volume ratio ##V_f / V_i##
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
