About Sodium Carbonate(Definition of base)
In summary, the definition of base states that a base is a chemical that reacts with an acid to form water and salt. Arrhenius bases, which increase the amount of hydroxide ions in an aqueous solution, are the most common. Brønsted-Lowry bases can act as proton acceptors, Lewis bases are electron donors, and sodium carbonate is a Brønsted-Lowry base.
abcd8989
44
A base is a chemical which reacts with an acid forming water and salt only.
Is this definition of base true?
If true, metal carbonates are not considered as base (carbon dioxide is also formed during neutralization which violates the definition). Hence, the solution of metal carbonates are not considered to be alkalis (since alkali is a subset of base). However, metal carbonates are usually basic, e.g. sodium carbonate. I am bewildered whether we can call sodium carbonate a base then.
Moreover, I would like to know the chemical reaction of sodium carbonate representing the production of OH- ions. Thanks very much.
Chemistry news on Phys.org
Arrhenius base: A substance which increases the amount of hydroxide ions when added to an aqueous solution.
Brønsted-Lowry base: A substance which can act as a proton acceptor.
Lewis base: An electron-pair donor.
Those are the most common, and the Brønsted-Lowry is probably the most used and the one implied by 'base' in general.
So, is sodium carbonate considered a base?
It's a Brønsted-Lowry base.
I find that definition true. There's really nothing complicated or more in-depth from the question. Bases are involved in neutralization reactions, which does product water and salt.
So, how do you explain high pH of solution of ammonia, or of solution of carbonate, or of solution of phosphate?
Well, all follows from the definition of base we're using. Sodium carbonate isn't a Arrhenius base, but it is a Bronsted-Lowry.
@Borek: I agree with Trooper100. Low pH of ammonia solution can be explained since NH3 acts as a proton acceptor. Low pH of phosphate and carbonate solutions are explained by the hydrolysis of the phosphate and carbonate ions.
I can be misreading something, but Trooper has just confirmed initial definition from the very first post:
Now combining it with your post:
Basically you have stated "base is a chemical that reacts with acid forming water and salt, but ammonia solutions are basic because ammonia reacts with water". Second part of what you stated can be not explained using definition you have listed first.
It is not that Arrhenius definition is incorrect, it is just limited and original question can be not answered using it.
FAQ: About Sodium Carbonate(Definition of base)
What is Sodium Carbonate?
Sodium carbonate, also known as washing soda or soda ash, is a white, odorless, and water-soluble inorganic compound. Its chemical formula is Na2CO3 and it is commonly used in the manufacturing of glass, soaps, and detergents.
How is Sodium Carbonate produced?
Sodium carbonate is produced through the Solvay process, which involves reacting salt (NaCl) and limestone (CaCO3) with ammonia (NH3) and carbon dioxide (CO2). This process results in the formation of sodium carbonate, ammonia, and calcium chloride.
What are the uses of Sodium Carbonate?
Sodium carbonate has various industrial and household uses. It is commonly used in the production of glass, soaps, and detergents. It is also used as a water softener, pH regulator, and food additive. In addition, it is used in the manufacturing of paper, textiles, and in the treatment of wastewater.
Is Sodium Carbonate harmful to the environment?
Sodium carbonate is considered to be a relatively safe and environmentally-friendly compound. However, it can be harmful to aquatic life if large amounts are released into water bodies. It is important to follow proper disposal methods and avoid excessive use of sodium carbonate to prevent any negative impact on the environment.
Is Sodium Carbonate safe for consumption?
Sodium carbonate is generally safe for consumption in small amounts. However, consuming large amounts can lead to health issues such as stomach pain, nausea, and vomiting. It is important to follow the recommended dosage when using products containing sodium carbonate and consult a doctor if any adverse reactions occur.
