About superconduct MRI quench protection
In summary, the conversation is about the design and implementation of quench heaters for the protection of superconducting coils. The purpose of the heater is to prevent the superconducting coil from exceeding temperature and high voltage in case of a quench. It is important to properly test and simulate the quench protection before using it, as it is a critical safety feature. The design process and calculations involved in determining the current and resistance for the heater are also discussed. The conversation concludes with the recommendation to seek professional help for the design and implementation of the quench protection system.
yunaijun
Hi,I study protection of superconducting coils.I adopt heaters to protect coils.The circuit is in attachment.
There are 6 coils,so I use 6 quench heaters.I want to know how I choose the heaters?
It must do the Quench Heater Simulation for protection of superconducting coils before experimenting.
So I need help about quench heater simulation.
who can tell me?Maybe you could tell me which website I should visit or which article i should read.
thanks
my email:
  • quench protection circuit.doc
Usually magnets are ramped to field and quenched in the factory before shipment and ramped back to field again just to ensure that they can handle quenching. So what is your goal?
thank you,I design the quench heater which prevent the superconduct coil from exceeding temperature and high voltage.
I don't know how design it.Could you introduce something to me?
The problem with quench protection in superconducting coils is that when a small section goes normal (quenches), the normal zone boundaries propagate away from the center with a velocity that depends on the current in the coil. At high currents the length of the resistive zone and the total resistance of the coil increases rapidly, which increases the voltage drop across the coil and causes the magnet current to be shunted through an external circuit (diode or thyristor). At very low currents, the normal zone will not grow, and there will be no damage to the coil. At intermediate cuurents, The normal zone will increase slowly, and if the total resistance of the coil does not grow sufficiently, the normal zone will heat up and damage the superconducting cable. The purpose of the heater is to cause the whole coil to go normal to limit the localized heat build up at the point of the quench. Usually the superconducting cable has a MIIT (pronounced "mite") limit. This stands for time integral of (mega amp*amp)dt, i.e., the heating at any point in the cable is integral[(I^2 R) dt] where R is the resistance per unit length of the normal (quenched) cable.
You mention experiments, how big is the magnet?
Always keep in mind that quench protection is NOT a "physics experiments"; it is a very important safety feature: get it wrong and things can go REALLY bad.
I don't know if anyone has ever been killed by a quenching magnet; but it could certainly happen; all you need is e.g. a blocked safety valve and you could get a pretty big explosion (remember what recently happened at LHC).
A few years ago I worked in a lab where a small cryostat (maybe 5l of helium) exploded, someone was warming it up when an ice-plug formed in the return-line and the safety valve didn't work for some reason. Fortunately, no one was in the lab at the time so no one was injured but the cryostat was just scrap.
My point is that you shouldn't be designing this unless you know what you doing. Get some help or hire a company to do it for you.
Also remember that all magnets/cryostats MUST be properly quench tested -not just simulated- before they are used routinely.
the circuit of quench protection is simple.(you could find it in the attachment)
MRI: 1.5T ,liquid helium 4.2K, NbTi/Cu .
the heating at any point in the cable is integral[(I^2 R) dt] ,I konw how calculate the propagation velocity (longitude,transverse),but how I could get I(CURRENT) or J(current density).Therefore,I couldn't get R,I.
could you give me some imply?
thanks
who could tell me quench programm(fortran or C++ or matlab)?
f95toli said:
Always keep in mind that quench protection is NOT a "physics experiments"; it is a very important safety feature: get it wrong and things can go REALLY bad. ...
Please read f95toli's message. Quench protection is not a computer program. It is an important safety feature.
It's evident that you don't know what you are doing. Given that, asking a bunch of people on the internet for advice is not all that much safer. You really need to get professional help with this.
Related to About superconduct MRI quench protection
What is superconduct MRI quench protection?
Superconduct MRI quench protection is a safety mechanism used in MRI machines to prevent damage to the superconducting magnets and other sensitive components in the event of a quench, which is the sudden loss of superconductivity in the magnets.
How does superconduct MRI quench protection work?
The system works by rapidly dissipating the energy released during a quench, using a combination of resistive shunts and cryogenic gas cooling. This prevents the temperature from rising too quickly and causing damage to the magnets.
Why is superconduct MRI quench protection important?
Superconducting magnets used in MRI machines are extremely sensitive and expensive, and a quench can cause irreparable damage. The quench protection system ensures the safety of the machine and prevents costly repairs or replacements.
What are the potential risks of a quench in an MRI machine?
In addition to the damage to the magnets, a quench can also cause significant downtime for the machine, leading to delays in patient care and research. It can also pose a safety risk to patients and staff if the temperature rises too quickly.
Are there any limitations or drawbacks to superconduct MRI quench protection?
While the system is highly effective, it does require regular maintenance and monitoring to ensure proper functioning. In rare cases, a quench may still occur despite the protection system, but the damage is usually minimized. Additionally, the initial cost of implementing the system may be a limitation for some facilities.
  • STEM Academic Advising
  • Electrical Engineering
