About the premises behind the Schrödinger equations
  • I
  • Thread starter snoopies622
  • Tags
    Schrödinger
In summary, Schrödinger's equation is a non-relativistic limit of an appropriate quantum field theory, and can be derived by making the following physical assumptions and then doing a trivial amount of substitution and differentiation.
snoopies622
846
28
Long ago I read on these forums that one cannot derive the Schrödinger equations because they're fundamental scientific laws. But I have noticed that I can generate them by making the following physical assumptions and then doing a trivial amount of substitution and differentiation:
(1) [tex] \frac {\partial ^2 \psi }{\partial x^2} + k^2 \psi = 0 [/tex]
(2) [itex] \lambda = h/p [/itex]
(3) Total energy = PE + [itex] p^2/2m [/itex]
and (4) [itex] E=h \nu [/itex]
where (4) is only needed for the time dependent form.
What bothers me is that (1) assumes a [itex] \psi [/itex] with a definite wavelength — that is — a momentum eigenfunction, and (4) was arrived at for photons, and of course the S.E.'s are used to deal with wavefunctions that are not necessarily momentum eigenfunctions and for particles that are not photons.
Thoughts?
You derived the Schrödinger equation limited to free particles with fixed momentum. It turns out that the equation is more general than that.
I did not derive it at all here, I'm saying that putting (1),(2) and (3) together it is easy to arrive at
[tex]
\frac {\partial ^2 \phi} {\partial x ^2} + \frac {8 \pi ^2 m }{h^2}(E - PE) = 0
[/tex]
and then adding (4) we can get
[tex] i \hbar \frac {\partial \phi} {\partial t } = E \phi [/tex]
and these forms are not limited to momentum eigenfunctions, nor are they for photons, yet (1) and (4) are connected to those physical premises.
In case you're wondering, I'll show you explicitly what I mean in an upcoming post.
What I had in mind was . . if we start with
[tex]
\phi = \phi_0 e^{i(kx-\omega t)}
[/tex]
and take the derivative with respect to x twice and rearrange terms, we get (1) in the original post.
Then if we plug in [itex] k=2 \pi / \lambda [/itex] , [itex] \lambda = h/p [/itex], [itex] KE = p^2 /2m [/itex] and E = KE + PE, we get the time independent form I cited in entry #3 above.
If instead we start with
[tex]
[/tex]
and take the time derivative once, then substitute [itex] \omega = 2 \pi f [/itex], f=E/h, [itex] \hbar = h/ 2 \pi [/itex] and rearrange terms, we get the time dependent form I cited in entry #3 above.
Thus we start with a [itex] \psi [/itex] with a definite wavelength and definite speed and yet end up with the general (one dimensional) Schrödinger equations.
Bumping an old thread from a couple months ago, hope y'all don't mind. I've given this matter more thought but still find it odd that one can produce the Schrödinger equations by making assumptions that are not entirely consistent with their general use. How did Schrödinger himself arrive at them? I have not seen his original paper.
Can you give a specific link to a post? This claim seems highly dubious to me since AFAIK it is perfectly possible to derive the Schrodinger equation as a non-relativistic limit of an appropriate quantum field theory, and in any case the Schrodinger equation, being non-relativistic, is obviously an approximation only.
Likes bhobba
Read this:
http://www.pnas.org/content/pnas/110/14/5374.full.pdf
Zz.
Likes bhobba, vanhees71 and Mentz114
Likes vanhees71, dlgoff and atyy
Thanks all. "Inspired guess" is what I figured. The mechanics-optics connection reminds me of something I read many years ago in a book on the history of physics — that had Hamilton lived long enough, he himself would have invented quantum mechanics.
If you wish to derive quantum theory as Schrödinger did, there is really only two fundamental assumptions ( with the addition that you would need to derive S-equations for each class of Hamiltonian).
1) Quantum theory is not classical, that is, the Hamilton-Jacobi equation is not true. A scalar, that measures "nonclassicality" for all the spacetime, can be introduced. The quantum theory is different then all other theories, that is, the scalar has an extrema (typically a minimum). This is philosophically the same as the principle of least action.
2) The theory that guides the "wavefunction" must be linear. The wavefunction is introduced intuitively, through the action.
Linearity is a very strong limitation, and with a correct choice of Hamiltonian, you can get back the S-equation with some variational calculus.
Read chapter 3 Ballentine.
Like so much of physics its real basis is symmetry - but you must read what I mentioned, then think. BTW Wigner got a Nobel for figuring it all out.
Thanks
Bill
For the detail see:
https://arxiv.org/pdf/1204.0653.pdf
He even made two errors that canceled each other out: Schrodinger’s notes [49] show that he was well aware that the solution of (8.12) gives correctly the bound state energies of the hydrogen atom before introducing in the anstaz concerning the hypothetical quantity J. This artifice compensates for the physically incorrect ansatz. The constant K should actually be the pure imaginary quantity −ih in which case (8.5) becomes the correct equation (7.27). Repeating Schrodinger’s stationary algorithm starting with the correct relation S = −ih¯ ln ψ would then give the incorrect equation (8.5)! Indeed, since the H-J equation and the properties of the generating function S already follow from Hamilton’s equations which in turn are a consequence of Hamilton’s Principle the condition that the action S should be stationary for arbitrary variations of space-time path it would seem that Schrodinger is attempting here to close a door that is already shut
Thanks
Bill
Related to About the premises behind the Schrödinger equations
1. What are the premises behind the Schrödinger equations?
The Schrödinger equations are based on two main premises: the wave-particle duality of matter and the conservation of energy. This means that matter can exhibit both wave-like and particle-like behaviors, and that the total energy of a system remains constant over time.
2. How are the Schrödinger equations derived?
The Schrödinger equations were first proposed by Austrian physicist Erwin Schrödinger in 1926 as a way to describe the quantum mechanical behavior of particles. They were derived using mathematical techniques such as differential calculus and linear algebra.
3. What is the significance of the complex numbers in the Schrödinger equations?
The Schrödinger equations use complex numbers to represent the wave function, which describes the probability of finding a particle in a certain location. The use of complex numbers allows for a more accurate description of quantum phenomena, such as interference and superposition.
4. Can the Schrödinger equations be used to describe all particles?
While the Schrödinger equations are widely used to describe the behavior of particles in quantum mechanics, they are not applicable to all particles. They are most accurate for particles with negligible mass, such as electrons, and become less accurate for particles with larger masses.
5. How do the Schrödinger equations relate to the uncertainty principle?
The Schrödinger equations are closely related to the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle simultaneously. The equations describe the probability of finding a particle in a certain location, rather than its exact position, which is in line with the uncertainty principle.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
