About the work done in moving a charge in an electric field
So, in summary, the work done by the external force in moving the charge from A to B is positive, but the work done by the electric field is negative as it opposes the motion.
bsmm11
An external force moved a positive test charge from A to B where B is closer to the centre of the field. Therefore, the force exerted by the field is from A to B.
The textbook is saying the work done is negative. But the external force moved the charge against the electric field strength as if a person moves a box to a higher place against the gravitational field strength, so wouldn't the work done by the external force is positive? Or is the force textbook is saying is the force by the field? If that is the case, when we are dealing with the work done in moving something in the field, is it usually work done by the field, not the external force?
The work done is indeed positive when an external force moves a test charge from A to B. The textbook is referring to the work done by the electric field, which is negative because it opposes the motion of the test charge. In general, when dealing with work done in moving something in a field, it's usually the work done by the field, not the external force.
FAQ: About the work done in moving a charge in an electric field
What is work done in moving a charge in an electric field?
The work done in moving a charge in an electric field is the amount of energy required to move the charge from one point to another in the presence of an electric field. It is calculated by multiplying the magnitude of the charge by the potential difference between the two points.
How is work done related to the force on a charge in an electric field?
Work done and force are directly related in an electric field. The force on a charge in an electric field is equal to the product of the charge and the electric field strength. Therefore, the greater the force, the more work is done in moving the charge.
Is work done in moving a charge in an electric field always positive?
No, the work done in moving a charge in an electric field can be positive or negative. If the charge moves in the direction of the electric field, the work done is positive. However, if the charge moves against the direction of the electric field, the work done is negative.
How does the distance between two points affect the work done in moving a charge in an electric field?
The work done in moving a charge in an electric field is directly proportional to the distance between the two points. This means that the greater the distance, the more work is required to move the charge between the two points.
Can the work done in moving a charge in an electric field be converted into other forms of energy?
Yes, the work done in moving a charge in an electric field can be converted into other forms of energy, such as heat or light. This is because work is a form of energy and can be transformed into different forms according to the law of conservation of energy.
