About vectors and vector products
In summary, the conversation discusses the use of dot product and cross product in determining the result when multiplying two physical quantities or vectors. These mathematical operations have specific meanings in the context of physics and can provide information about the angle between vectors or the area of a parallelogram.
kapoor_kapoor
If two physical quantities are being multiplied , is there any way to know that the result will be a scalar of vector.. Moreover if two vectors are being multiplied how can we know that we have to apply cross or dot product??
You need some context. "Two physical quantities" is too vague for it to be possible to know what is going on. Physical quantities can be many different forms. Temperature would presumably be a scalar. The velocity field of a fluid would be a vector field. The stress in a solid is probably expressed as a tensor. And so on.
"Being multiplied" is likewise too vague to understand what is going on. For example, some quantities are a scalar times a scalar in some contexts. In other contexts they might be a scalar times a vector. Or a cross product. Or a dot product.
Dot product and cross product are mathematically defined vector operations, resulting in a scalar or a vector respectively. Physics gives particular meaning to the results.
A dot product will get you the angle between two vectors.
A cross product will get you a new vector that presumably represents some physical property (angular momentum, torque, etc). Geometrically, the magnitude of the cross product gives you the area of a parallelogram whose sides are defined by the two vectors you took the cross product of.
Likes kapoor_kapoor
Related to About vectors and vector products
1. What is a vector?
A vector is a mathematical quantity that has both magnitude and direction. It is often represented by an arrow pointing in the direction of the vector with a length proportional to its magnitude.
2. How are vectors represented?
Vectors can be represented in several ways, including using Cartesian coordinates, polar coordinates, or using a column matrix. In physics, vectors are often represented using unit vectors in the x, y, and z directions.
3. What is a vector product?
A vector product, also known as a cross product, is a mathematical operation between two vectors that results in a third vector. It is used to find the direction and magnitude of a vector that is perpendicular to both of the original vectors.
4. What is the difference between a dot product and a cross product?
The dot product of two vectors results in a scalar quantity, while the cross product results in a vector quantity. The dot product measures the projection of one vector onto another, while the cross product measures the perpendicular component of one vector to another.
5. How are vector products used in real life?
Vector products have many applications in physics, engineering, and mathematics. They are used to calculate torque, magnetic fields, and forces in three-dimensional systems. In computer graphics, they are used to create realistic lighting and shading effects. In navigation, vector products are used to calculate the direction and speed of a moving object.
  • Other Physics Topics
  • Calculus
  • Linear and Abstract Algebra
