Asphyxiated
- 264
Absolute Convergence, Conditional Convergence or divergence...
[tex] \sum_{n=1}^{\infty} \frac {(-2)^{n}}{n^{n}} [/tex]
[tex] \lim_{n \rightarrow \infty} | \frac {a_{n+1}}{a_n}| < 1 \;\; absolute\; convergence [/tex]
[tex] \lim_{n \rightarrow \infty} | \frac {a_{n+1}}{a_n}| > 1 \;\; divergence [/tex]
[tex] \lim_{n \rightarrow \infty} | \frac {a_{n+1}}{a_n}| = 1 \;\; inconclusive [/tex]
Other tests may be used such as AST but this section is about using the ratio test and we are suppose to use that unless it is inconclusive.
First I changed the sum by factoring out the alternating part of it, so maybe I went wrong there:
[tex] \sum_{n=1}^{\infty} \frac {(-2)^{n}}{n^{n}} = \sum_{n=1}^{\infty} \frac {(-1)^{n}(2)^{n}}{n^{n}}[/tex]
So if that's right then here is what I did to set up the ratio test:
[tex] \lim_{n \rightarrow \infty} | \frac {(-1)^{n+1}(2)^{n+1}}{(n+1)^{n+1}}* \frac {n^{n}}{(-1)^{n}(2)^{n}}| [/tex]
[tex] \lim_{n \rightarrow \infty} | \frac {(-1)(2)(n^{n})}{(n+1)^{n+1}}| [/tex]
At this point I drop the (-1) due to the absolute value bars, the denominator can be written as (n+1)^n(n+1) due to the exponent but I don't know where to go from here:
[tex] \lim_{n \rightarrow \infty} | \frac {2n^{n}}{(n+1)^{n}(n+1)}| [/tex]
This is evidently equal to zero if I type it into my TI-89 which makes it absolutely convergent but I can't see how to get there algebraically. If I try to use L'Hopital's rule in the numerator I will get n^n (ln(n+1)) for as many time as I feel like taking the derivative. And if I type the fraction into maple and tell it to simply I simply get the same function back again.
Thanks for the help in advance!
