Absolute Entropy in an isolated gas
In summary: The Maxwellian distribution will hold over time. Even if all the velocities were unformed, the uncertainties of interactions would effect a non-uniform distribution. This would lead to the maximum entropy.
Austin0
1,160
Given an ideally isolated volume of a single species of gas that has reached internal equilibrium , would the individual molecules :
[A] Retain the range of individual velocities and thermal energies [if present] and keep a merely statistically constant average?
OR
Would they equalize those energies over time becoming virtually identical within a range of quantum indeterminancy?
[C] Somewhere in between??
I hope this makes sense and is addressable in its generallity .
Ie: It is not a ,"Well , you see,it all depends" , kind of situation.
Thanks Cheers
Science news on Phys.org
Sorry i didnt understand your question.
The distribution of velocity of a perfect gas in thermodinamic equilibrium is the Maxwellian. What's the point?
Ll.
Ll.
Hi Thanks for your responce. My question is trying to understand the limits of entropy.
Whether given sufficiently long time the distribution of velocities would be completely equalized Ie: every molecule having the same velocity or whether the Maxwellian distribution
would pertain over ANY timespan.
From your responce I take it that the statistical range would endure indefinitely.
Logically that is what I assumed but I may have been thinking too much in terms of Hawking magic boxs. Thanks
This intuitive argument might help a bit.
The second law of thermodynamics implies that the number of microstates increases over time. If all your speeds are the same, then they are all in states with the same speed; there is only way to pick the speeds of the particles to do this. However, if your speeds follow a Maxwell-Boltzmann distribution, then the speeds are spread out and this gives many possible ways to pick the speed of each particle.
In short, with all speeds equal the system would have a much lower entropy than it would if the speeds were spread out. It's the Maxwell-Boltzmann distribution that gives the greatest entropy; since entropy cannot decrease, the speeds will stay in this distribution forever.
Thanks --that makes complete sense and was a real help
Austin0 said:
the Maxwellian distribution would pertain over ANY timespan.
Well, not indefinitely : a gas returns to its initial condition due to Poincarè recurrence theorem.
But this happens in a HUGE time scale, so huge that the second law of thermodinamic holds in physics.
Ll.
Ll.
_________________________________________________________________________
I will look up that Poincare theorem.
SO for all practicle considerations , the Maxwell distribution will hold.
From this am I correct in assuming that even if we created a situation where all the velocities were unform, that over time, the uncertainties of interactions would effect a non-uniform distribution? Maximum entropy.
Thanks for your help, it has been spot on for resolving my question.
FAQ: Absolute Entropy in an isolated gas
What is absolute entropy in an isolated gas?
Absolute entropy in an isolated gas refers to the measure of disorder or randomness in a system of gas molecules that is completely isolated from its surroundings. It is a thermodynamic property that is related to the number of possible microstates that a gas can have at a given temperature and volume.
How is absolute entropy calculated?
Absolute entropy can be calculated using the formula S = k lnW, where S is the absolute entropy, k is the Boltzmann constant, and W is the number of microstates available to the gas at a given temperature and volume. This formula is based on the statistical mechanics concept of microstates and macrostates.
What is the relationship between absolute entropy and temperature?
There is a direct relationship between absolute entropy and temperature. As the temperature of an isolated gas increases, the number of microstates available to the gas also increases, leading to an increase in absolute entropy. Conversely, as the temperature decreases, the number of microstates decreases and so does the absolute entropy.
What happens to absolute entropy in an isolated gas as it expands?
When an isolated gas expands, its volume increases, and therefore the number of possible microstates also increases. This leads to an increase in absolute entropy. This is because the molecules of the gas now have more space to move around and more possible positions and configurations, resulting in a higher degree of disorder or randomness.
Can absolute entropy be negative?
No, absolute entropy cannot be negative. This is because absolute entropy is a measure of disorder or randomness, and negative values do not make sense in this context. The lowest possible value for absolute entropy is zero, which occurs when the gas is in a perfectly ordered state with no possible microstates.
