Absolute Extrema on Open Intervals
In summary: This is because the function is unbounded on the open interval, so the absolute maximum cannot exist.In summary, finding the absolute extreme values of a function on an open interval is not guaranteed, and it is important to check the end behavior and limits of the function to determine if absolute extrema exist.
Qube
Problem 2:
Find the absolute extreme values of f(x) on the interval (1, infinity).
Paul's Calculus notes said:
1. We say that f(x) has an absolute (or global) maximum at if for every x in the domain we are working on.
2. We say that f(x) has a relative (or local) maximum at if for every x in some open interval around .
3. We say that f(x) has an absolute (or global) minimum at if for every x in the domain we are working on.
4. We say that f(x) has a relative (or local) minimum at if for every x in some open interval around .
It seems as if this is an indiscretion by the teacher. Absolute extrema don't occur on open intervals except in the case of (-∞,∞) such as in case of sin(x). Am i missing something?
That is not true. Look at the end behavior of the function.
Also, I'm confused of what you mean by "except in the case of [itex](-\infty, \infty)[/itex]" every unspecified domain is assumed to be on that interval, and checking for absolute extrema is the same.
The theorem you want says something like this: If f has an absolute extremum on an open interval (a, b) then it must occur at a critical point of f.
Then look at the limits:
[itex] \lim_{x\to a^+}f(x)
\lim_{x\to b^-}f(x)[/itex]
If you have a closed interval for the domain, you can find absolute extrema, but on an open interval you're not guaranteed to find them. This is not the same, however, as saying that you will not find an absolute extremum on the open interval.
Take for example f: (-1,1)->R defined by f(x)=x2. It has an absolute minimum at x=0, but no absolute maximum.
FAQ: Absolute Extrema on Open Intervals
What is an absolute extremum on an open interval?
An absolute extremum on an open interval is the largest or smallest value that a function can take on within that interval. It is also known as the global extremum, as it represents the overall maximum or minimum value of the function on the interval.
How is an absolute extremum different from a local extremum?
An absolute extremum is the largest or smallest value of a function on the entire open interval, while a local extremum is the largest or smallest value of a function within a specific interval or point. A local extremum can exist within an absolute extremum.
How do you find the absolute extrema on an open interval?
To find the absolute extrema on an open interval, you need to first find the critical points of the function within the interval, which are points where the derivative of the function is equal to zero or does not exist. Then, evaluate the function at these points and at the endpoints of the interval. The largest and smallest values will be the absolute extrema.
Can a function have more than one absolute extremum on an open interval?
Yes, a function can have multiple absolute extrema on an open interval. This can occur when the function has multiple critical points within the interval or when the endpoints of the interval are also the absolute extrema.
What is the significance of finding absolute extrema on an open interval?
Finding absolute extrema on an open interval allows us to determine the overall maximum and minimum values of a function within that interval. This information is useful in many applications, such as optimization problems in mathematics and predicting the behavior of systems in science and engineering.
