Absolute min/max (algebra+solving for zero), Rolle's Thrm
In summary, Lucas can't understand how to solve equations by contradiction. There are 5 equations that need solving and 4 of them have no real solutions. All of the solutions where cos(t) = 0.
LucasCLarson
Hey everyone. Just getting prepped for a midterm on Tuesday and looking for a bit of help on a few things. If there are any tricks to make some of this stuff easier that would be great. I remember there being a few from back in high school, but i can't remember them. I know the process for all of these, but some of the algebra is pretty tough. Non of the answers are posted so it would be great to have a bit more insight.
We aren't allowed to use calculators either.
Solving these equations [f'(x)] for 0 to determine the critical points (min/max) of the original function:
1) f(x)=(x^(1/3))((4-x^2)^(1/2)) [-1,2] ;
f'(x)=(sqrt(4-x^2)/3((x^2)^(1/3)) + x^(1/2)(.5(4-x^2)^(-1/2)
2) f(t)=sint+cos2t [0,pi/2]; f'(t)= -cost-2sin2t
3) f(x)=x+cos(x/2) [pi/4,7pi/4]; f'(x)=1-(1/2)sin(x/2)
4) f(x)=x-lnx [1/2,2]; f'(x)= 1-(1/x) (this seems easy, but when i try to determine the intervals of increase and decrease it makes no sense. the C.P. should be at x=1 [where f'(x)=0], but the intervals don't show a max or min.)
Rolles: I can't grasp the concept of solving by contradiction.
5)Show the equation 1+2x+x^3+4x^5=0
1) i tried to find a common denominator but wasn't sure were to go. If you multiply two sqrt functions both obviously cancel each other out, but do you still multiply/foil the stuff inside the sqrt?? sqrt(4-x^2) x 2sqrt(4-x^2) ??
2) difficult to grasp without a clac. Any pointers on solving mathematically. I know all of the intervals of pi, i also recognized that if i can find the intersection of cos & sin of the original function on the interval i should have my answer.
3) No idea: 0=1-.5sin(x/2) = -2=sin(x/2) (function never reaches -2)
4)Interval problem:
5)Use IVT to show that a root exits. I chose a=-1 and b=1 f(a)<0<f(b), and because f is continuous(polynomial) a root exists for f(x) on the interval (-1,1) such that f(c)=0
Rolles:
F is a polynomial so it is certainly continuous and differentiable.
and f(a)=f(b) then there must be a number N such that f'(c)=0
My problem: Am i supposed to use the interval i used to prove there was a root ([-1,1]) or doesn't it matter? My book shows that f(a)=0=f(b); is that because it was the root given for my original equation or because i know there must be a point such that f'(c)=0. I know that f'(x)=2+3x^2+20x^4 will always be greater than or equal to 2. Now, how to i prove that only one root exits by contradiction?
Thank you very much!
Lucas
anyone?
I think you're making some minus sign dropping errors!
2) f(t) = sin(t)+cos(2t)
f'(t) =cos(t)-2sin(2t)
0 = cos(t)-2sin(2t)
2sin(2t) = cos(t)
2(sin(t)cos(t) +sin(t)cos(t)) =cos(t)
4sin(t)cos(t) =cos(t)
4sin(t)=1
sin(t) = 1/4
don't forget the solutions where cos(t) = 0
3) I think you dropped a minus sign, I get:
2=sin(x/2)
yeah no real min/max solutions
4) graphing it on your calculator might help here
[itex]
f(x) = (x^{ \frac{1}{3} })(4-x^2)^{\frac{1}{2}}
[/itex]
[itex]
f'(x) = ( \frac{1}{3}x^{ - \frac{2}{3} })(4-x^2)^{\frac{1}{2}} +(x^{ \frac{1}{3} })( \frac{1}{2})(4-x^2)^{- \frac{1}{2}}(-2x)
[/itex]
[itex]
0= ( \frac{1}{3}x^{ - \frac{2}{3} })(4-x^2)^{\frac{1}{2}} +(-x^{ \frac{4}{3} })(4-x^2)^{- \frac{1}{2}}
[/itex]
give it a shot from here?
5) since the derivative is always positive the function is always increasing. It's also continuous therefore it can only pass the y=0 line (and every other line y = constant) once if at all.
hope these help, think them through and then let me know if anything was confusing :cool:
thanks a lot for the help. I was able to get them figured out! I was being an idiot on the 1-1/x fcn.
I have another Rolles question as well. I will post it at the top.
Thanks
Nevermind, looks like i can't edit for some reason.
here is my question.
show x^3-15x+c=0 has at most one root on the interval [-2, 2].
My work/attempted solution.
Using the IVT i determined that there is a possible root (N=c) within the interval of [-2,2]. because c is my constant i decided to Use [d] as my letter for explanation.
f(x)=x^3-15x+c
f(d)=d^3-15d+c
0=d^3-15d+c
-c=d^3-15d
f(-2)=22=-c
c=-22 when for f(-2)
f(2)=-22=-c
c=22 for f(2)
f is continuous on [-2,2] because it is a polynomial. Let -c be a number b/w f(-2) and f(2) where f(-2) does not equal f(2). Then there exist a root d on (-2,2) such that F(d)=-c
I am stuck there. I feel like i have done a bunch of stuff wrong so a little nudge in the right direction would be great.
Thanks
FAQ: Absolute min/max (algebra+solving for zero), Rolle's Thrm
What is the absolute minimum and maximum of a function?
The absolute minimum and maximum of a function are the lowest and highest points on the graph of the function. These points represent the smallest and largest values that the function can attain.
How do you find the absolute minimum and maximum of a function?
To find the absolute minimum and maximum of a function, you need to take the derivative of the function and set it equal to zero. Then, solve for the critical points by finding the x-values where the derivative is equal to zero. Finally, plug these x-values into the original function to find the corresponding y-values, which represent the absolute minimum and maximum.
What is Rolle's Theorem?
Rolle's Theorem is a mathematical theorem that states that if a function is continuous on a closed interval, differentiable on the open interval, and the function's values at the endpoints of the interval are equal, then there must be at least one point in the interval where the derivative of the function is equal to zero.
How do you use Rolle's Theorem to find the roots of a function?
To use Rolle's Theorem to find the roots of a function, you need to first check if the function satisfies the conditions of the theorem. Then, find the x-values where the derivative of the function is equal to zero using the theorem. These x-values represent potential roots of the function, which can be verified by plugging them into the original function.
Can Rolle's Theorem be applied to all types of functions?
No, Rolle's Theorem can only be applied to continuous functions on closed intervals. If a function is not continuous or if the interval is not closed, then the theorem cannot be used to find the roots of the function. Additionally, the function must also be differentiable on the open interval for the theorem to be applicable.
