Absolute pressure, buoyant force, tension problem
In summary, the diving sphere has a mass of 150,000.0kg and an external diameter of 7.000 meters. It is anchored with a cable at the bottom of the ocean at a depth of .8000 km. The absolute pressure at that depth in pascals is 8.145E+6 Pa. The buoyant force felt by the sphere when it is completely submerged is 1.471E+6 N. The tension of the cable is 3.120E+8 N.
jenn91890
A diving sphere has a mass of 150,000.0kg and an external diameter of 7.000 meters. The sphere is anchored with a cable on the bottom of an ocean, at a depth of .8000 km. The density of sea water is 1025.0kg/m3.
A) What is the absolute pressure at that depth in pascals?
B) What is the buoyant force felt by the sphere when it is completely submerged?
C) Calculate the tension of the cable.
A) P = Ps+DgH
P=?
Ps=1.01E+5Pa
D=1.025E+3kg/m3
G=9.81m/s2
H=.8000km
B) P=F/A, A=pi R2
P=(from above)
BF=?
R=3.5m
C) WF=m*g
TF+WF=BF
m=150,000kg
g=9.81m/s2
TF=?
BF= (from above)
A) P=(1.01E+5) + [(1.025E+3)*(9.81)*(800m)]
=8.145E+6Pa
B) 8.145E+6Pa = BF / (pi * 3.5)2
BF=3.135E+8N
C) WF=150000*9.81
WF=1471500
TF=313500000-1471500
TF=3.120E+8N
Is this correct? The numbers seem very high...
Hello and welcome to PF!
Is the depth .8000 hm or .8000 km?
Your method for part (a) is correct. For part (b) you have not calculated the BF correctly. Consider Archimedes' principle.
Your approach to part (c) looks correct.
km, I have corrected the typo.
for part (b) density=mass/displaced volume
so displaced volume = mass/density
so displaced volume = 150,000/1025
so displaced volume = 146.341
BF = density * displace volume * gravity
BF=1025 * 146.341 * 9.81
=1.471E+6
No, this isn't correct. 150,000 kg is the mass of the diving sphere, but 1025 kg/m3 is the density of sea water.
Try to think of another way to get the displaced volume. Hint: geometry.
=1.471E+6
Your calculations become a lot more intelligible if you state the units after each result. It's a habit you should cultivate now.
What is the volume of a sphere 7 m in diameter?
Chet
Related to Absolute pressure, buoyant force, tension problem
1. What is absolute pressure?
Absolute pressure is the total pressure exerted by a fluid, including both the atmospheric pressure and the pressure exerted by the weight of the fluid itself.
2. How is buoyant force calculated?
Buoyant force is calculated by multiplying the density of the fluid, the acceleration due to gravity, and the volume of the displaced fluid. This force acts in the opposite direction of gravity and is what causes objects to float or sink.
3. What is the relationship between buoyant force and an object's weight?
Buoyant force and an object's weight are directly proportional. As the weight of an object increases, so does the amount of fluid it displaces and therefore, the buoyant force acting on it.
4. How do tension problems relate to buoyant force?
Tension problems involve calculating the force exerted on an object by a string or cable. In the case of buoyant force, the tension in a string or cable attached to an object is equal to the buoyant force acting on that object.
5. How does absolute pressure change with depth in a fluid?
Absolute pressure increases with depth in a fluid due to the weight of the fluid above it. This is known as hydrostatic pressure and follows the equation P = ρgh, where P is pressure, ρ is the density of the fluid, g is the acceleration due to gravity, and h is the depth.
